IBM ThinkPad T23 2647 Notebook Logo
Posted on Sep 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display the display on my sceen is off centre, there is about an inch on the left hand side that is black, and the whole bottom of the screen is lost, (ie task and start bar).. however i can run it perfectly if i plug in an additional monitor, and the driver i have installed is up to date.
Anonymous
Level 2:
Sergeant:
  • Expert 457 Answers
  • Posted on Sep 14, 2007
Anonymous
Expert
Level 2:
Sergeant:
Answers
457
Questions
0
Helped
332111
Points
799
LCD problem nearly dead.......I tried to see where you live but its not specified. In the States they have this place you can try: http://lcdrepair.net
Dell sx2210 how do I change the size of the screen?
  1. Navigate to the Control Panel in Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display. Note: In Microsoft Windows , depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that saysSwitch to Classic View.
  3. In the Display Properties window, click on theSettings tab.
  4. Locate the Screen resolution slider on the left-hand side of the window. Under most circumstances, the best choice is 800 by 600 pixels or 1024 by 768 pixels, possibly higher if you're using a 19" or larger monitor. The "best" setting is highly subjective to your personal preferences.
Display on laptop screen
You may have inadvertently pressed the correct hot keys to change the display around. In the bottom right hand corner of the screen you may have an icon for your graphics. If you click, or right click you can get the properties up. You should be looking for something which refers to screen orientation ie from landscape to portrait or vice versa.
3helpful
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
1helpful
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
3helpful
3answers
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
2helpful
4answers
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
2answers
Black blank 5.5 inch Line
new pcb board put in spent over £300 on a new PCB board.
give me the link of this on ebay plz.
The whole screen is shifted 1 inch to the left.
When in high def and on the PC the formate buttom on the remote is disabled. The formate will have to be done with the high def remote or through the PC. You will have to contact the high def and the PC provider to adjust the format.
Background display
OK....in XP Home and PRO SP2 a bug cause this to give vga shift.....reinstall OS with XP SP1 and the problem would be solved....there is currently no solution for this. JJ
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
