Back to:
Tags:
Irons
Generic problem for all Irons
Steam Iron (by 5 users)
posted by Rocketman001 on Sep 14, 2007
My Steam iron keeps cycling on and off without fully heating up.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Feb 18, 2008
I have the same problem with the auto off. I've tried the plug/unplug routine which does no good. Perhaps a new iron that is not a Rowenta? Any new suggestions on this problem?
Comment by kemper, posted on Feb 17, 2008
Red light flashes and does not heat properly,when iron is unpluged and pluged up again,it will heat up for a few minutes and then cool down.
Comment by JoeGecsey, posted on Dec 21, 2007
With the setting at 4, 5, or 6 (not maximum) the iron acts as if the motion-detection is not working and goes into the auto shutoff mode even with use. The red light flashes. The only -but rather inconvenient solution - is to unplug the iron, wait a few seconds, and then plug it back in. This action apparently resets the auto shutoff, but the cycle begins a few minutes later - the red light begins flashing again and the iron starts to cool.
Comment by sharon92167, posted on Nov 03, 2007
How to I clean my iron
Best Solution
posted on Sep 21, 2007
Thanks for Trying (70)
oscarn
Rank:Wiz Wiz
Rating: 76%, 58 votes
Try setting the thermostat to a little less than maximum
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Steam Iron:
I don't want to Accept this solution
Solution #2
posted on Nov 11, 2007
Not Rated (0)
luckyrgood
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This iron appears to have a problem related to the auto-off function.
Regardless of manufacturer's advice, no amount of moving or shaking will reset the function.
Sorry, Oscar, but the thermostat setting has no effect.
Thank You!
Can you Help with these Irons problems?
Irons
I cant find my operator manual and the de-calc light is...
Irons
I recently purchased a Kenwood Steam Generator iron Model...
Tefal UltraGlide 1759 Iron
Every time i iron, the iron somehow gathers fabric...
Rowenta Commercial Garment Steamer - White
Steamer heats. I can pour water into the boiler from the...
I have an rowenta commercial garment steamer. I think the...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
