Question about Panasonic NV-GS25 Mini DV Digital Camcorder
Software problem The software which I got is not supporting windows vista. What Ishould do? From where I can get the software for VISTA
  • 1 more comment
  • maciong Nov 17, 2007
    I am also encountering the same problem as ukunni..apparently the software is only supporting microsoft xp, at the moment I am using vista...so please help me if how can I install it to my vista, or do u have an available software for vista..
    Many thanks
  • Anonymous Jan 06, 2008
    i lost the cd
  • doni romdoni Feb 08, 2008
    i lost the cd
  • 47 Answers
You have two options to get the software working with Vista:
1. Go to the Panasonic support site and search for a set of batch files that can be combined into an executable patch for your software for Vista.
2. This seems to be the easier method. Insert the disc, then browse the contents of the CD and find the executable files on that disc for the software installation. Right-click the executable (or MSI if applicable) and go to Properties. Find the Compatibility tab and select compatibility mode for XP SP2 and check the box to Run as an administrator. Now the software should install successfully.
For those that have lost the disc, you would need to call within 30 days of purchase of the camera to receive a software replacement at no charge. We would require the model number of the camera and a copy of your receipt or other POP to verify it is the model you stated and the date of purchase - it would then be ordered at the parts department and shipped to you. If not, you would need to purchase other software or use any existing software you may have.
If you're concerned about driver software, the issue would be which OS you're using. I suggest calling 800 211 7262 for more information.
Posted on Mar 05, 2008
I lost the cd
Posted on Feb 08, 2008
SOURCE:
Want to load lotus on to a vista system.....can I??
  • The Notes 8.0 feature release (released in August 2007) was fully tested and is supported with Windows Vista.
  • The Notes 7.0.3 maintenance release (released in October 2007) was fully tested and is supported with Windows Vista.
  • Notes 7.0.2, the in-market Notes release (shipped in September 2006) when Vista was released on January 20, 2007, is supported on Windows Vista. Releases prior to Notes 7.0.2 are not supported on Windows Vista.
  • Due to the broad changes in the Windows Vista release, and no more 6.5.x Maintenance Releases, Notes 6.5x is not supported on Windows Vista.
Nov 15, 2009 | IBM Lotus 123 Millennium Edition 9.5...
Tip
How To Diagnose HP All-in-One Scanners
<a href="/ftp://ftp.hp.com/pub/softlib/software12/COL34826/oj-90928-1/HPSDU.exe">HP Scan Diagnostic Utility</a> was created to help users troubleshoot and correct connectivity problems with HP All-in-One devices and software on Windows-based computers. Follow the on-screen instructions to run the utility.<br /><br style="font-style: italic;" /><span style="font-style: italic;">This utility is compatible with Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Ultimate (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP</span><br /><br />You could also try running the HP System Check if you have <a href="http://h50203.www5.hp.com/HPISWeb/customer/SupportProds.aspx?region=NA">any of these supported products</a>. HP System Check automates and speeds the resolution of computing problems, acting as a Web-based diagnosis and resolution service. System Check offers a unique combination of Web based trouble-shooting software and world-class hardware diagnostics, providing the most comprehensive array of online support solutions in the industry. Check your system by <a href="http://h20239.www2.hp.com/techcenter/HP_SystemCheck/hp_syscheck.htm">clicking here</a>.
on Feb 21, 2011 | Office Equipment & Supplies
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
WINDOW VISTA
I think ur Vista is pirated or not cracked version. First of all install the full version of OS, after that problem will solved. There is no supporting version of office 2007 with vista, whenever any software is not supported with vista the problem is OS itself. so try to uninstall it. reinstall OS
Feb 13, 2009 | Microsoft Office Professional 2007 Full...
I have vista not suporting the software of webcam
You can try this link to download the software for windows vista.
Please select the appropriate product.
http://support.creative.com/kb/ShowArticle.aspx?sid=39881
Hope this will be useful.Thank you.
Dec 02, 2008 | Creative Labs Live! Cam Notebook Pro...
Hi there i cannot get my mp500 to work on vista please help kind regards teresa
Windows Vista This product can be used with Windows Vista.
  • To use it with Windows Vista, install the software for Windows Vista.
  • The Windows XP software for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Beforeupgrading your OS from Windows XP to Windows Vista, delete / uninstallall the Windows XP software first; then, upgrade the OS to WindowsVista and install Vista software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall Windows XP software before installing Windows Vista software.
For Windows Vista driver just click the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=11995#DownloadDetailAct
I hope it helps!!!
Dec 01, 2008 | Office Equipment & Supplies
Canon pixma500
  • To use it with Windows Vista, you must install the driver software for Windows Vista.
  • The Windows XP drivers for your product cannot be used under Windows Vista.
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP driver software first; then, upgrade the OS to Windows Vista and install Vista driver software.
Delete / uninstall the Windows XP drivers before installing Vista drivers.
I hope it helps!!!
Nov 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
Window vista
Ask the shop where you brought the laptop and ask for a copy of windows vista. If you brought vista home basic, then you should have the cd also.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Phone photo software download, windows vista
Actually the problem is that your photo software dont support windows -vista. So if you want to know that it supports window vista......use google.com and find it that by now it supports vista or not..
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
Regards :
dilipbagdi
Technical Associate
Apr 29, 2008 | Computers & Internet
Navigator for pixma mp500
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP software first; then, upgrade the OS to Windows Vista and install Vista software.
You can download from
Driverscollection.com
Mar 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
Panasonic NV-GS25 Mini DV Digital Camcorder Logo
125 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
