Laptop will not turn on.
The Compaq shows no indication that power is being applied. The power brick was measured and it show 18plus volts.
  • cebuwano May 11, 2010
    will it on if using new charge battery? if yes, then something is wrong along the dc input line of your laptop. a broken inductor that cuts the supply to go into your system. you can replace it with any wire serve as jumper then solder with no problem. your problem may be lies on how to dismantle the laptop and look for this small inductor. you may able to find it by focusing on the line in of your dc power supply. somewhere along this is cut. you need to have a multimeter to find it. let us know.
    Problem Solver:
  • 12 Answers
If there are no apparent physical defects on the laptop, power cord, or battery and the laptop is not receiving any power even when plugged in then either your power cord or some circuitry in your laptop have become damaged. If your laptop is still under warranty sending it off to HP for repair will be your cheapest solution, otherwise you may try replacing the power adapter.
Posted on Apr 15, 2009
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
Monitor turns black
As you had stated that the monitor is working if the power brick is off.The back light shutdown might be a cause of static from your power brick, or other thing is it might be your setting for back light level or power scheme.Some configuration needs to open BIOS settings.To check if the power brick is the cause of problem is good to have a known good one or try to monitor if it is charging or not by monitoring the battery indicator if the power brick is off.
Feb 13, 2012 | Dell Latitude D430 Notebook
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
When i turn tv on the power button shows its on but no pic or sound
the power supply of your TV must be check.the power output of the power supply suppose to be 12 volts for audio,24 volts for the backlight lamp and 5volts for the main CPU. use a multimeter to measure the voltage In the case of your TV it seems only 5 volts is present that is why you have a power indicator lit....open the back cover of your TV and measure the power supply.power supply board is where the power cord is connected...
Apr 19, 2011 | Sansui HDLCD3200 TV
My son also has a HP/Compaq Presario CQ61 and his too suffers from the problem mentioned by others - The p[ower light goes next to the power jack input goes out after a few seconds and the Laptop will not...
Have you tried a new power brick or tested the original?? it should measure around 19 volts and you should be able to draw at least 3 amps from it.
(Be aware that if you have a short circuit in the computer it could destroy another brick connected to it).
Mar 07, 2011 | Compaq Computers & Internet
"battery doesn t charge how do I know if the power cord or the battery is bad on my Presario M2000
If the battery is over a year old then it could be dead.Anything over two years I would bet on it. Usually the power bricks are very reliable. To check it you just need to put a power meter on it and check the voltage against what is printed on the brick. It should be slightly higher.
Without a meter it is pretty hard to check. You should get some indication that it is plugged in. It may have a power light on the brick or the laptop that shows it on even if it wont charge.
Mar 23, 2010 | Compaq Presario M2000 Notebook
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
Laptop compaq presario v2000 is not charging the battery. It is functioning well on external power supply. The battery has been replaced with new barttery but it is not showing the charging status but...
This is probably either a bad power supply brick or a bad system board. Try to borrow a power brick from somebody else to see if this fixes the problem so you can isolate it as this is a much less expensive problem to fix.
If you have a travel charger, be sure to press the button on top to put it in charge mode.
Aug 28, 2009 | HP Compaq Presario V2000 Notebook
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
