Question about SanDisk Sansa e260 MP3 Player
Getting messgae Not enough space for MusicDB. Please free 6MB
I am getting the above mesasge on my Sansa e260. I get it everytime I turn it on and off. I lost all my music it is not even listed. I tried reseting to the factory defaults but that did not seem to work. I can use all the features of my e260 but I cannot load any music to it. When I connect my e260 my pc does not even reconize it. It will charge but that is it. I tied the scandisk website and did not get anywhere. Does anyone have any idea how I can get get rid of this message so I can download music to my e260. Thanks Ken
  • 626 Answers
If it wont connect to the PC, you need to put it into recovery mode and format it with the recovery tool from SanDisk. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 15, 2007
In windows
format using command window
type
format g: (where g is the letter of your sensa player)
Posted on Nov 30, 2008
Your only option is to use the "Format Device" option. I've had to do this twice. It does not delete your music files but it does recreate the database.
SOURCE:
When i turn the player on it says Not enough space for music DB Please free 6 MB. But it says in the info Memory 0MB and Free 0MB
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the musicto the sansa keep about 6MB of free space
Dec 23, 2010 | SanDisk Sansa e260 MP3 Player
MusicDB please free 6 MB
u need to format the player....simple as that....
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
How to free music db space
my sansa clip will turn on but then it says not enough space for musicdb please free 30mb how do i do that and when i hook it up to my systeam to look at the music files it show nothing please help
Jun 26, 2009 | SanDisk Sansa Clip MP3 Player
What do i do when i get - not enough space for MusicDB, free 6MB????????????/
free up that much space for you sdmini to be recognized by the player let it refresh and start loading your files on the sdcard and left over memory on the player
Mar 01, 2009 | SanDisk Sansa e260 MP3 Player
I lost my free [email protected]!!!
The error message says, please free up 6MB for Music DB (database).
Connect the device to your computer and remove several songs. Restart the device, and you should be back to normal.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
E250 Please free 6MB!!!
solution #1 : try HARD resetting it by holding the power button for 15 seconds. if not solution #2 : install and use this tool to repair your sansa. Its called the Sansa Connect Recovery Tool. You get on the sandisk website, you have a manual also . go to : http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Jul 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
231 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
