Question about Dell 3000cn Laser Printer
Ink dots on right side of paper
There are several ink dots/splotches on the right side of the paper....on every print job. We have replaced the toner cartridges several times, but it continues to happen. How do I fix this?
  • Anonymous May 15, 2009
    I have this problem, I'm getting ink spots on the side of the paper it's on all copies. Does this mean I need a new image drum? If so where do I buy one? Can I buy one at a store near me or do I need to order it from Dell? Do I sound pathic well I'm going crazy with this problem. Thank you for any help.
  • 4 Answers
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Posted on Apr 15, 2009
Ink dots on pages
You might need a new toner or ink. if it is a copier, check to see if there are specks on the glass where the paper is placed.
Jan 21, 2013 | Brother HL-4040CN Laser Printer
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
Dots on page
shivan, did you change the toner if it yes then open printer and clean the surface of toner and the roller see is there any dust or ink powder is there. bye
Sep 22, 2007 | Brother HL-5280DW Laser Printer
Dell 3000cn Laser Printer Logo
286 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
