Question about Macromedia Dreamweaver MX 2004
Connectivity how to connect a databse with dreamweaver. and which script will be best .
// Connects to your Database
mysql_connect("", "username", "password") or die(mysql_error());
mysql_select_db("Database_Name") or die(mysql_error());
//This code runs if the form has been submitted
if (isset($_POST['submit'])) {
//This makes sure they did not leave any fields blank
if (!$_POST['username'] | !$_POST['pass'] | !$_POST['pass2'] ) {
die('You did not complete all of the required fields');
// checks if the username is in use
if (!get_magic_quotes_gpc()) {
$_POST['username'] = addslashes($_POST['username']);
$usercheck = $_POST['username'];
$check = mysql_query("SELECT username FROM users WHERE username = '$usercheck'")
$check2 = mysql_num_rows($check);
//if the name exists it gives an error
if ($check2 != 0) {
die('Sorry, the username '.$_POST['username'].' is already in use.');
// this makes sure both passwords entered match
if ($_POST['pass'] != $_POST['pass2']) {
die('Your passwords did not match.');
// here we encrypt the password and add slashes if needed
$_POST['pass'] = md5($_POST['pass']);
$_POST['pass'] = addslashes($_POST['pass']);
// now we insert it into the database
$insert = "INSERT INTO users (username, password)
VALUES ('".$_POST['username']."', '".$_POST['pass']."')";
$add_member = mysql_query($insert);
Posted on Dec 13, 2007
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
Dec 24, 2010 | GPS
How to import Xara menu in Dreamweaver?
make a div tag -link the javascript file, then insert <script menumaker src="gfx/menu_.js"></script> into the tag and then u can see the menu using live view
May 22, 2010 | Xara Menu Maker 1.1 Full Version for PC
Recommendation of the dreamweaver cs4
Windows Dreamweaver System Requirements
In order to run Dreamweaver CS4 on the Windows platform, you need the following minimum system requirements:
* 1GHz or faster processor
* Microsoft® Windows® XP with Service Pack 2 (Service Pack 3 recommended) or Windows Vista® Home Premium, Business, Ultimate, or Enterprise with Service Pack 1 (certified for 32-bit Windows XP and Windows Vista)
* 512MB of RAM
* 1GB of available hard-disk space for installation; additional free space required during installation (cannot install on flash-based storage devices)
* 1,280x800 display with 16-bit video card
* DVD-ROM drive
* Broadband Internet connection required for online services
Macintosh Dreamweaver System Requirements
In order to run Dreamweaver CS4 on a Macintosh, you need the following minimum system requirements:
* PowerPC® G5 or multicore Intel® processor
* Mac OS X v10.4.11–10.5.4
* 512MB of RAM
* 1.8GB of available hard-disk space for installation; additional free space required during installation (cannot install on a volume that uses a case-sensitive file system or on flash-based storage devices)
* DVD-ROM drive
Hope it Helped!
Aug 26, 2009 | Adobe Dreamweaver CS4 for Mac
Dreamweaver FTP Error
i would suggest that your server ip address has possibly changed. I would contact the people who support your server and ask them if anything has changed.
the fact that your website is up and running does not mean that the FTP should work. Very often your FTP server is physically separate to your web server
please rate this answer if it has been useful
Feb 16, 2009 | Macromedia Dreamweaver MX 2004
I want connet foxpro databse to visiual basic
Using a DSN-less connection to open a free table
cn.Connect = "SourceType=DBF;" _
& "SourceDB=C:\Vfp\Samples\Data;" _
& "Driver={Microsoft Visual FoxPro Driver}"
Jan 20, 2009 | Computers & Internet
Uploading a SWF -
All sorted, i did not upload the script. Having done that it now works.
Dec 10, 2008 | Macromedia Flash MX
How to connevt visual basic with oracle(sql)
You need to install oracle client on client machine, and than you can use datasource (ODBC) to connect from vb to oracle.
Jan 23, 2008 | Computers & Internet
Dear peedamutu, javascript is a client side scripting language that works with browser. To learn it completely please read following tutorial
please press fixya if that hashelped you.
Dec 12, 2007 | Macromedia Dreamweaver MX 2004
Popup menu
Put you javascript part in between head tag..
<script language="javascript">
<!-- begin
function popup(Site)
// end -->
And add the following code into your <BODY> tag:
Your <BODY> tag should then look something like this:
<BODY bgcolor="#ffffff" text="#000000"
Note: In this and all script examples that follow, change the attributes "toolbar", "statusbar", etc., to on (1) or off (0) as you prefer (or omit them), and set the width and height to the size you require.
Oct 16, 2007 | Adobe Photoshop 7.0 for PC
How to make up a design using the dreamweaver?
Macromedia Dreamweaver for the first time, or on a new site for the first time, you need to define the Web site so that Dreamweaver can work with it. This process includes naming the site, placing the local files on a directory on your hard drive, and showing Dreamweaver where those files will be published on the Web. Follow these easy instructions to define a new Web site for Dreamweaver .
First, you should go to the "Site" menu and choose "Manage Sites".
As you can see from the image below, this will open a dialog window. Choose "New Site" from the "New" button.
Open Dreamweaver and Start the Site Definition Wizard
Name Your Site
Using Server Technologies on Your Dreamweaver Site
Where Should You Edit Your Dreamweaver Site Files
Defining Access to Your Dreamweaver Site
Always Test Your Connection
Site Check-out and Check-in with Dreamweaver
Review Your Site Definition
Your Site Now Appears in the Manage Sites Window
Start Editing Your Files in Dreamweaver
Oct 11, 2007 | Macromedia Dreamweaver MX 2004
Macromedia Dreamweaver MX 2004 Logo
110 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
