Question about Jabra BT500 Wireless Headset
Unit won't charge and I get no lights
When pluging in the headset to the usb cable and either to the computer or to the ac adaptor I get no indication of the unit charging.
  • 6 more comments
  • MickeyG Sep 24, 2007
    Like you, I went directly to Jabra for a resolution. They are sending a replacement at no cost.
    It's been about two weeks and still haven't received the replacement.
  • zalim Dec 16, 2007
    I have got the same problem. I have contacted Jabra and waiting for reply. I charged the bluetooth and it doesn't turn on any more.
  • Anonymous Dec 25, 2007
    Same problem here. I have constant flashing red ligth, but the unit still won't charge. I have been charging it now for over 12 h, and it still flashes.
    Yep, got a BT500 for each kid, and NEITHER of them will charge. When you plug it in, the red light flashes briefly, then it changes to a green flash for a second, and then the light goes out for good. Both have been charging now for over 7 hours, so I suspect I got 2 bad ones (what are the odds without there being some sort of class problem?). I confirmed the charger works by plugging my working BT500 into the charger, and the light comes on normally. Will call retailer tomorrow for RMA.
    As a side note, the wife and I both have these same units, and we love them; hence the reason for getting them for the kids.
  • chanR Dec 26, 2007
    On charging the unit for over 12 hrs, all I see is a red blinking light and when I try to switch on the unit while it is plugged in it does not work.
  • racer_rr Apr 30, 2008
    I just tried three units off my company's supply shelf and ALL THREE will not take a charge. They are brand new and have been sitting there for 6 months. FREAKING JUNK!!!
  • sugarmonkey Aug 12, 2008
    I also am experiencing this problem. I've contact Jabra. I'll let you know how it goes. It had a 1 year warranty, which I'm sure is expired by now, but we'll see if they decide to do anything about resolving this situation.
    Spending more than one hundred dollars for a headset each year seems a little counter intuitive.
  • alaaedin Apr 08, 2009
    I've gotten many of these and when they work they're great but it looks like a common thing with these. I just got 7 of them and 5 just having the flashing red light which by now I know that means they're bad.
I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. Hope this helps.
Posted on Sep 20, 2007
Posted on Apr 30, 2008
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
My usb cable will not charge my psp
Are you plugging the charging plug into the PSP?There are two plugs on the USB cable 1.the USB plug. 2.the charger plug itself. The USB cable looks like the other end that plugs into the computer only smaller.The charger plug looks like the ordinary AC adaptor.
Also note that You need the computer/device that the PSP is connected to,must be turned on,well this is true with mine anyway.
Also the USB does not charge the PSP as fast as the AC adaptor.
Oct 02, 2010 | Sony PlayStation Portable (PSP) Console
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
Are you suing the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If no please purchase KLIC7001
Now in case you are using this KLIC7001, How do you charged the camera or battery? USB cable or AC adaptor? If your using USB cable actually some of the M893 will not charged using USB cable you need to update the firmware or download the firmware before you can successfully charge it using the USB cable
Now if the AC adaptor make sure when you plug the adaptor theres a light indicator on the camera and charged the battery for 4hrs., and still the camera will shuts off everytime you take a picture please call kodak toll free 1 800 235 6325 have your camera repair. Gudluck!
Nov 05, 2009 | Cameras
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
4pr909 bluetooth headset chargine issue
It may be defective. Even if its not charging well it should still light up if there's a charge connection. Return it if you can and buy a better one.
Apr 21, 2009 | Cell Phones
Omnitech 2.0 Bluetooth headset. No charge indication?
I have the same headset. Make sure that when you place it in the little charging cradle that the ends are snugly fitting together. It is a very flaky design in my opinion.
If all else fails, call OmniTech (800.351.0245) and see what they can do about it.
Apr 07, 2009 | Cell Phones
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Mar 15, 2009 | SanDisk Sansa Fuze MP3 Player
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Jabra BT500 Wireless Headset Logo
1,261 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
