Question about Kenmore 63942 Dryer
Kenmore model# 96281100 elect. dryer
Dryer heating element glows red while I'm trying to explain to wife that nothing is wrong with the dryer. Then, as soon as I turn my back or leave, it goes out, and wife swears dryer is still not fixed because clothes are still wet. Everything else works fine. Help!! Jimbo331
  • jimbo331 Sep 16, 2007
    Dryer is in a basement with no venting what so ever, so clogged or "pinched" venting cannot be the issue here.
    jimbo
    President:
  • 878 Answers
Jimbo, this dryer uses a cyling thermostat to turn the heater on and off. If your vent is pinched or clogged, or the vent to the outside is clogged, you are going to have long dry times and damp clothes. Try doing a load with the vent disconnected from the back of the dryer. If everything turns out ok, then it's a venting issue. Catriver
Posted on Sep 15, 2007
SOURCE:
Kenmore dryer model 11062972100 does not heat up. Element does not appear to be broken. any ideas?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 14, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No electric flows to glow element on kenmore gas dryer 8798 0100 79801. there is continuity in glow element and fuse and flame detector.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 28, 2010 | Dryers
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore mid 1994 110 96281100 no power to element
Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 12, 2009 | Kenmore 659 Electric Dryer
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
My Kenmore Elite Electic dryer mod #11063012101
OK .. on your dryer it does have a bi-metal switch that turns on and off the element....if your dryer produces heat... nothing wrong with element.. a thermostat w/wire sensor is the only way to check for your heat if its working correctly.. the other is to check if your clothes coming out of your washer is it wetter then before.. might need to spin one more time.. good luck..
Jan 13, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Dryer shuts off minute or two into drying cycle
not sure with out model # but if there is a rmovable lower panel and dryer has even heat control bd suspect control also look for a thermistor this is a black thermastat looking part with 2 small wires mounted to blower housing beside a white thermal fuse
May 21, 2008 | Kenmore Dryers
Kenmore 63942 Dryer Logo
189 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
