Question about Philips Magnavox 51MP392H Rear Projection Television
3-d effect it appears on the top and bottom of screen it slowly progressed inward
My magnavox 52" has a 3-d effect it appears on the top and bottom of screen it slowly progressed inward
  • 10,594 Answers
This convergence out ICs failure symptoms in TV and you need to replace two convergence out ICs in convergence out section / board in TV
if you are not familiar with TV repair then call qualified Tv tech to fix it.
Posted on Apr 15, 2009
Big screen RCA 52" flash green light on three times and shut off. Will not stay on , had a tech look at it he said power supply. We replace that, it continue to do the same thang. Now techician saying its...
power supply's are hardly ever replaced, they are repaired. your picture tube in most cases usually fail slowly progressively over time, there are many protection circuits involved in a TV`s circuit, they protect your unit from faults like power supply faults, picture convergence, vertical amplifiers, x ray, ext depending on your model, i suggest you search out a second opinion form another organization before spending 600 plus dollars for a new tube, i suspect your tech may be a little less than honorable...
Apr 26, 2010 | Philips Magnavox 9P6034C 60" Rear...
Maganavox 51mp392h/17 double objects at top and bottom of screen.
You need to replace your convergene ICs. It's best to call a repairman for this job.
Aug 09, 2009 | Philips Televison & Video
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Philips Magnavox 51MP392H Rear Projection Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
