Hobart 24 in. LXIC-5 Built-in Dishwasher
Problem for Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart dishwasher lxic detergent pump will not run
By agonzalez011 on Apr 15, 2009
I have a lxic dishwasher and the detergent pump will not run during wash cycle but I did check the pump and it does work I opened the panel to check if the pump was off on the curcuit board program but I don't know the steps on how to change the program Thanks
Solution #1
posted on Jul 09, 2009
Not Rated)
weevoe
Rank: Apprentice
Rating: 100%, 1 votes
Is the pump shaft turning during the wash cycle? If so I bet it is the same problem I had with my sanitizer pump on my 24" LXIc. remove the pump cover plate & replace the internal tube. Search this site for hobart LXIc sanitizer problem.
Was this helpful?
Yes
No
Solution #2
posted on Apr 19, 2009
Not Rated)
dimifriend
Rank: Apprentice
Rating: 75%, 1 votes
it supposed to work throgh the washing cycle,therefore you better trace,and inspect the line of the detergent,maybe it'stuck somewhere,and if it's ok check the panel board.does the pump receive voltage through the washing cycle.
Was this helpful?
Yes
No
Popular Solutions for Hobart 24 in. LXIC-5 Built-in
Questions and Unsolved Problems for Hobart 24 in. LXIC-5 Built-in
Do you recommend Hobart 24 in. LXIC-5 Built-in Dishwasher?
Answer
Answer
The machine shuts off as it is filling. This is a randomly occurring problem. We will use the... (More)
Answer
LX-18 Hobart need 2 detergent pumps. Can I buy these aftermarket or must they come from hobart
Answer
hobart lx18 no power to detergent pump, during the wash cycle there is no power present at the... (More)
Answer
Temperature in our sanitizer only reaches 90-95 degrees instead of 165. What could be the problem ?
Answer
I think my machine may be programmed for the 6% hypo-chlorite sanatizing solution and my supplier... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 24 in. LXIC-5 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
