Question about Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill
How to change the chuck on a draper red line 18v cordless drill
The chuck has a screw in the middle
i have tried many different wasy and nothing works
  • 154 Answers
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
Posted on Apr 15, 2009
My Dewalt cordless drill, model DC970, is fully charged and turns. However, when I try to turn a screw, the drill does not move. What should I do?
There is a collar that controls the torque of the driver just behind the chuck. Rotate it until the drill icon lines up for full power.
Mar 05, 2015 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Oct 12, 2013 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
Aug 31, 2013 | Ryobi 18v Variable Speed Impact Driver...
How to change the drill head
If you man changing the chuck, take out any drill bits and look down into the chuck. You will see a screw holding it on. On many drills this screw has a reverse thread so it loosens in the opposite way to regular screws. You have to undo this screw to remove the chuck, then fit a new one of the same spec or one suitable for the drill and reassemble in reverse order.
Mar 31, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck wont come off dewalt cordless drill 18v xrp my chuck bolt insid of the chuck wont come out and i need to know if it is reverse thred or not
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
Mar 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I have a thor electric drill. I am unable to remove the chuck on the drill. can you help?
Open up the old chuck all the way and there is a screw down in the middle of the chuck, unless it is missing. The screw is left-handed threads. Remove the screw. Take a large allen wrench. Tighten down in the old chuck. The chuck is right handed threads. Lay the tool down on its side. Take a hammer and hit the other end of the allen wrench several times until the chuck comes off (some of them are on very tight). If it doesn't come off, then spray WD-40 down inside the chuck and let it sit overnight or for a few hours and then try it again.
Don-www.toolsandmachinery.com
Feb 20, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill Logo
658 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
