Question about Kyocera Finecam L4V Digital Camera
"Cover opened" error message
Every time I turn on the digicam, there is an error message "cover opened" appear on the screen. in the "play" mode there only a blue screen and an error message, in the "photo" mode I can see picture by the lense (no problem with the lense), but the shutter can't operate and the message still appear. I 'm using a Lithium battery
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 15, 2007
SOURCE:
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Sir my pc has automatically restart and does not worked proprely they can give the fatal error plzz helpp me
Are you getting a Blue Screen error and can't read it because the computer keeps restarting?
If So, turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Scroll down past safe mode and you will see an option to Disable Automatic Restart. The next time you boot up you will be able to see the error message.
If it is a Blue Screen Of Death (BSOD) error message, you might need a system disc.
Mar 26, 2012 | Dell OptiPlex GX620 PC Desktop
Error is occured.
Blue sreen problem occurs either faulure of Hardware or software and solution is right the message which is displayed on blue screen so you need to look at message once and follow the procedure according to blue screen.
if you are not aware of it then please post back the message which appears on blue screen.
and vote all answeres.
Mar 04, 2009 | Microsoft Windows 98 for PC
I can't take pictures....
This error message TURN THE POWER OFF AND ON AGAIN is a common error message for digital cameras that has a zoom lens. One possible cause for this is that the battery may had drained out and the lens is still extended. There would be different that steps you could perform and make sure you have fresh or fully charged batteries when performing these steps.
First of course try to do what the error states.
If will not work, set the unit in PLAY mode before turning it ON or immediately right after you press the power. If it successfully gets through the PLAY mode, initialize the settings and restart th camera. You could initialize it by going to the menu and then setup.
If still will not work, turn it off and also remove the battery and allow it to have no power at all for a minute.
If all the steps above will still not work. your camera would require service and try calling its manufacturer to setup a repair on it.
Apr 07, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Can't take new pictures!
 Delete some images then try
Still in trouble?
Come back
Oct 16, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Kyocera Finecam L4V Digital Camera Logo
168 people viewed this question
Top Kyocera Cameras Experts
Ekse
Harrie
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
