Question about Garden
Real hard to pull to start - Garden
Remove agitator on WJSR4160D5CC
grab at the bottom of agitator and pull real hard. Might want to try giving it a hard yank to get started.
Feb 14, 2015 | GE Washing Machines
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
The rip cord wont pull to start pulls once and then wont pull real hard to pull
try squeezing the wand when you are starting the motor.
it will let the water pressure go through.
Nov 24, 2010 | Honda Pressure Washer PSI 3000
Hard to start, following the starting prosedure shown on the top of the blower it requires 10 real hard pulls to get it to start
If you are having to pull that many times something is wrong. It should only take about two or three pulls to get it started. Prime, choke and pull one time than that the choke off and pull again. it should start.
It may have some parts loose that may need to be looked at by a shop.
Good day.
Oct 16, 2009 | Garden
I have a 1997 chevy silverado. When it sits for a day or two it starts real hard. It begins to turn over normal and then turns over real low and slow and then goes back to normal and finally starts. My...
Sounds like you may have faulty field coils within the starter. You can take it off and go to a starter/alternaor shop and have it check, they can ascertain if it is pulling excess amperage, and either make repairs or replacment unit.
Aug 11, 2008 | Chevrolet Silverado Cars & Trucks
Garden Logo
119 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
