Question about Refrigerators
Norcold mod 1095 no cooling code .reset board works for3hrs reset once lasts for2hrs then it quits again dealer had for 2weeks says it works fine .we run it on lp
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: norcold n1095 not working on AC...works fine on LP
Yes. LP is direct heat to the exchanger. The thermistor operates through the control to the electric heater.
Posted on Apr 22, 2009
gordanddar
  • 477 Answers
SOURCE: norcold refrigerator igniter not generating a
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
Posted on May 27, 2010
heatman101
  • 43501 Answers
SOURCE: norcold n621 fridge not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 14, 2010
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
Norcold refrigerator igniter not generating a spark. I can light the flame with a lighter, but once refrigerator reaches desired temperature flame goes out and when more cooling is needed a spark is not...
Apr 05, 2010 | Thetford Norcold RV Cooler/Freezer
Error message reading NO co is beeping.
I have done a bit of google research and this code probably means "Not Cooling" Due to a power interruption or sometimes if you do the initial cool down from 12v (instead of gas or AC). There are a couple of other causes but often all the unit needs is a reset. I found some details and instructions here but they don't specify an exact model. There were other details here but they refer to pages that are no longer available..
This should put you on the right track. Just do some more googleing if these details aren't specific enough.
Aug 16, 2009 | Thetford Norcold RV Cooler/Freezer
Fault code on norcold refer model 640.3 reads "no" "co",how do I reset
u must take into a dealer or have a mobile tech to reset the board
Jul 29, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold mod 1200 does not cool well in Az. during the summer time
air circulaton over the cooling unit on norcold is critical get out you owners manuakl look up baffels and make sure all are in tact and also no animals have made a home behind you refer you have done all you can do inside the problem lies on the outside of the refer where the cooling unit is
Jul 22, 2009 | Thetford Norcold DE0051 Refrigerator
Norcold rv refrigerator freezer
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Norcold RV Refrigerator
It sounds like the relay could be stuck closed on the electric side of the board. This would not allow the element to stop working. Sometimes resetting the board will fix this problem if it is still under warranty they will cover both the board or the resetting.
Aug 07, 2008 | Refrigerators
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
