Question about Sharp Microwave Ovens
Is a 16 year old Sharp Model R-5A54 Microwave worth having repaired and if so, how do I find a place to fix it in the Detroit area It won't come on at all........is there a fuse in it?
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Lost the LED display on
We repair those for US and Canadian customers, but in the UK you can contact Quality Electronic Repairs.
Posted on Aug 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp quartz chef combination
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a helpful link you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
The best place to order Sharp parts in the US is Tritronics.
Posted on Aug 18, 2008
rylee_smith
  • 8619 Answers
SOURCE: Dead microwave!
Hi Kevin
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If still you are unable to diagnose the issue then it is recommended to call a local repair center for this to get fixed as Microwave usually have high voltage even when it is turned off.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 24, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp model R-1871 shuts off every 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 30, 2009
Testimonial: "traced to motor for damper. Would not have had a clue without this information provided by fixya"
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
My 3 year old ge profile microwave model pvm2070sm4ss made a buzzing noise and stopped heating. What can be the likely cause? Do you repair this in detroit? If yes, what would be the cost and need a...
Before you try getting it fixed, try unplugging it from the wall and let it sit for an hour, then plug it in and try it, the safety switch will sometimes re-set and it will go back to normal.
Mar 18, 2015 | GE Microwave Ovens
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
The electrical outlet is on. The microwave is completly dark. It's 16 years old. What should i do? Fix it or buy a new one.
After 16 years, I should think you had your money's worth from this machine.
There are a few arguments for fixing it, if it's repairable, but a new one will be more powerful while being more efficient too. (use less electric)
Less radiation leakage too.. (pacemaker exposure?)
Perhaps you should first try shopping around to see if you find one that you like, and that fits in the space you have for it, etc. If you buy a new one, get a good one. Don't go cheap.
If one seems to make good sense to you, then buy it. If nothing looks good to you then find a repair shop to take old one to.
Why would you keep old one? Well first of all, they don't make them like they used to. Lot of new ones are noisy and rattle a lot. Don't last nearly as long. Many new ones have problems early.
Old ones are lower power, which is slower, BUT food heats more evenly because of it. Less prone to exploding food.
Feb 28, 2011 | Whirlpool MH7135XE Microwave Oven
Panasonic microwave model NN-2959: can't open door.
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Sep 11, 2009 | Microwave Ovens
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Interactive display only shows half the letter and number.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the full service manual for this model at our site, linked above.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 04, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
218 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
