Question about Apex Digital GB51HD09 51" Rear Projection Television
Service menu i need service menu codes for apex gb51hd09 tv to raise scrolling on bottom screen that is being cut off or the necessary codes to shrink picture top to bottom.
The volume on my tv just stopped working.
Posted on Aug 07, 2011
On my Apex TV screen, some of the picture is cut out. How can i adjust the TV resolution?
You cannot adjust the resolution in CRT TVs. Its not like a monitor that is compatible with a number of resolutions from a computer for example. CRT TVs resolution's dont work like that.They take an input usually from a composite, Svideo or coaxial source and display it on the screen.
When you say the picture is cut out is there a black bar on top/bottom/middle of the screen? In older CRT TVs that usually means a problem with the TV itself and would need to be taken in for repairs or replaced.
Mar 05, 2011 | Apex Digital AT2708S 27" TV
Apex GB51HD09 convergence
Please have it taken care of ASAP. It definitely sounds like Cold Solder joints on the convergence IC's. Cheap repair now, if you stop playing it. Every-time the convergence goes out, the ic's struggle to bring it back in and can't and therefor over heat. so please have it taken care of Pronto. Apex used a Samsung chassis which was a good chassis in that PTV.
Aug 19, 2009 | Apex Digital GB51HD09 51" Rear Projection...
Screen is to big
Either the TV or the cable/satellite receiver has Zoomed in to the image when parts of the picture are cut off. Look at both remotes for a Zoom feature or the onscreen menu's for any settings. Usually TV settings don't change on their own but cable/satellite receivers can receive updates and it may need to be reset afterwords, much like a PC.
Oct 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Apex 32 inch tv Model #PF3230
try to reset the settings of the tv. check the manual on how to reset it.
Aug 27, 2008 | Apex Digital PF3230 32" TV
Can't see the scroll at the bottom of the screen
I was having the same problem. if you turn the vol. down to 00 then press mute on the remote then hold mute on the remote and menu on the tv for 3 seconds you will get the service menu and you can adjust the screen.
hope this helps.
Mar 07, 2008 | Apex Digital AT2708S 27" TV
Over projection on apex hd 51"
try to go to menu using ur remote and adjust the v-size/vertical size....
Jan 29, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Can't see scrolling text or sport scores
Here's how to fix it - I have a PF 2425, and it's driven me absolutely up the wall. Videogames are useless because you can't even see the crucial gauges etc. Likewise, subtitles and credits in films are cut off. it's ridiculous, especially considering how easy it is to fix (if you know how).
1. Decrease volume to 0.
2. Press MUTE so the tv says "MUTE" onscreen.
3. Hold MUTE on the REMOTE and MENU on the TV simultaneously until the service menu appears.
It's important not to screw around here too much. Use your arrows on the remote to navigate, the first option likely will say "MENU.0" or something like that. Use that to flip through the pages. What you're looking for are values like V Zoom, V Scroll, etc. Same goes with the H values. Toy with these a little and you'll be able to get the tv scanning perfectly.
I can confirm this worked for me! So good luck.
Dec 08, 2006 | Apex Digital PF2725 27" TV
Cannot make horizontal and vertical size and position adjustments
OK...I paid a whole $50 for an Apex AT2702 that had [undisclosed] vertical zoom, horizontal shift, vertical shift and width issues. Before I raised hell for the person who sold it to me, I decided to first exhaust all alternative solutions.
I found that in order to tweak these settings, you have to be in service mode and must have a service manual which I can email upon request.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE !!!
1-Reduce your tv volume to 0
2-press the MUTE button on your original tv remote [you'll see "Mute" in red on the screen]
3-AT THE SAME TIME, press MUTE on the same remote and MENU on the tv controls.
This set your tv into service mode [there will be a red "S" at the top-center of your screen.
You'll need the table in the service manual page 47 where there are V-SHIFT, H-SHIFT, V-ZOOM, E/W WIDE default values that will need to be changed. WATCH YOUR SCREEN as you change the values to ensure you don't over do it.
If you have news ticker and sports scores issues, you'll want to be tuned to CNN, FOX, ESPN or whatever to see how your changes are applied.
If you have tv guide problems then tune to that channel or press info and see what happens when you make the changes.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE.
This has worked for my set and you may attempt this solution on yours at your own risk.
I'm no longer pissed off that I got a bogus tv because it now works just fine and I can see everything!
Good Luck!
Jul 31, 2006 | Apex Digital AT2702 27" TV
Apex Digital GB51HD09 51" Rear Projection Television Logo
190 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
