Question about ViewSonic VA1912WB 19" WideScreen Monitor
I have a hp w1907v moniter that has speakers but no sound.
  • Anonymous May 22, 2009
    The monitor was functioning before, but now, even though the stereo cord is plugged in properly to the monitor and PC tower, there is no sound. I've already checked the sound manager and it isn't muted.
I have a hp w19b moniter and everything is hooked up even the speakers. However the speakers have yet to work. I have made sure there plugged in and everything.
The speakers in this monitor require a powered speaker output, and most audio cards only provide a line level output, which is not enough to drive these.
You may need to go out and get another sound card like a creative labs or the like - but make sure the card has a SPEAKER out on it, and not just a line level output.
You may be better off simply going out and getting a set of powered speakers!
Jun 22, 2011 | HP W19b LCD Monitor
Would like to connect speakers. Does this computer have a sound card in it? Moniter is hp w1701. Does it have speakers in the moniter?
well depends on the Computer brand! most computers come with a sound card... sometimes there is onboard and pci :) either way look behind your computer where all the plug-ins are and there should be 3 small holes that will allow the plug of speakers... :) hope this helps!
Aug 08, 2010 | HP Computers & Internet
Bought a new compac computer and I can't get any sound from my HPvs15 monitor
Be sure to connet the sound card speaker and install sound drivers for the moniter to get it to work you can go to http//www.hp.com select compaq and slect your model to download the correct drivers, also make sure you don't have any speakers muted in the mixer driver by double clicking on the speaker on the lower right hand corner on the lower right hand corner.
Jul 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
No sound on my moniter
You need a separate audio cable from the sound card to the monitor for the sound to get into the moitor and out its speakers.
Nov 26, 2009 | HP Pavilion F1523 15" LCD Monitor
My sound will not work
Try running the diagnostic tool or performing the PC DOCTOR tool for audio device. the system sould tell you what went wrong for the audio device.
Jun 20, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Jun 14, 2009 | HP w2207 Monitor
Logitech x-540 speakers wont work??
unplugg your hdmi cable and use a regular monitor cable then plug your speakers in to your sound card
Feb 27, 2009 | Logitech X-540 Computer Speakers
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
Speakers not working
Your problem is prevalent anywhere , whosever around the world,,, you had tried everything but nothing happened? Well , the porblem is internal....if you are a hobbyist, you may open your monitor and try checking the circuits where the speaker is being located, check for loose solder. busted wiring , or the speaker itself, maybe one of the wires is cut or dislocated. Word of wisdom,,, bring your monitor at nearby electronic shops if you wish spend a little of your savings. This way you may out of electric shocks if you do it after all. Leave it to the experts....good luck
Apr 03, 2008 | HP Compaq Computer Speakers
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Computers & Internet Logo
560 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
