Question about Kodak ImageSource 50 Copier
Getting a F34-2 Code, what does that mean and how can I fix it
I have a Kodak Image Source M50cp that is thowing an "F34-2" code. What does it mean and how can I fix it?
jqsababa967
  • 145 Answers
SOURCE: code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Posted on Nov 29, 2008
SOURCE: Error code F34 on Konica 1015 copier is there any
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Posted on Mar 12, 2009
jqsababa967
  • 145 Answers
SOURCE: I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Mar 14, 2009
team leader
  • 40 Answers
SOURCE: Our Konica #2125 is displaying
this code for fuser unit but make sure about this code is that's f34-1 or f34-2
anyhow you need to rest this code
Posted on Sep 01, 2010
  • 825 Answers
SOURCE: Kodak Image source 50. Turn on machine and 5
Turn Off the printer and then turn it back On. If the message persists, service is required, contact Service personnel...!
Posted on Dec 15, 2010
Kodak easyshare w1020. I lost my activation code
EasyShare software may no longer be activated. Since Kodak declared bankruptcy, they have taken the the activation server off line. You will need to find another image editing software package.
Sorry about the bad news,
Bax
Nov 11, 2013 | Kodak EasyShare
Kodak easyshare w1020 activation code
Bax
On the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
F 28 error code on a mhwe450ww
"F28" fault code means the communication between the Central Control Unit (CCU) and Motor Control Unit (MCU) cannot be sent correctly. See image below for additional information. NOTE: Disconnect the power cord from the power source before removing any panels.
there is likely a loose wire connection at the MCU, CCU or at the motor. The intermittent "F28" could also be caused by a loose solder joint on CCU or MCU. This type of intermittent failure can be very hard to pin point (click over image for zoom)...
Hope helps.
Apr 23, 2011 | Washing Machines
Kodak Image source 50. Turn on machine and 5 seconds shows i55 error code. I have tried to reset on service mode but it comes back again.
Dec 15, 2010 | Kodak ImageSource 50 Copier
8X10 photos print very bad
What do you mean by very bad - Does the image look bad? If so hold down the COPY and PHOTO button - A Demosheet prints out, how does that look? If the same: go to ww.kodak.com/go/itg and follow the instructions there. If it looks perfect then there's an issue with the source of your images
Oct 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
E37 code on a kodak image soucre 50 copier/similar to canon 6050
Kodak E37 = Canon E0005
Its Mean The Web Roller Is Over
Replace The web IN heater Roller Or Clean The Web Sensor.
Mar 09, 2009 | Canon NP 6050 Copier
Kodak 5100 all in one printer, 3802 code
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk or www.kodak.com
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Jan 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
41 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
