Question about MIA Moda Viva Infant Car Seat - Flame
Securing with or without base
I just want to know if I can secure this car seat without the base? ie - does the base have to be used all the time or can the seat be buckled in on its own. MIA Moda Viva Infant Car Seat
  • 3 Answers
I did a search and came up with this site http://www.healthchecksystems.com/product/?product_id=9530. it doesn't say specifically if you can use it with our without a base. But it does have a video demo and larger pictures. It looks like on the side of the seat there is a part that is black where there is no cover, that is where the seat belt should pass. Any of my infant car seats that can be used without the base have been just like this. Hope this helps!
Posted on Apr 15, 2009
Diagram uberhaus dual flush toilet leaking from bolts securing tank to the base
If the tank base has a good seal and when attached properly it will not leak. If the tank base has a line fracture or is pitted, it will leak. Inspect the base and the port the base sits in for any defects. Overnighting bolts can sometime cause damage to the seat and the only way to fix that is to use a silicone seal from a tube and apply lightly around the base, put the tank in place, tighten moderately, and let it sit unused for 24 hours until the seal cures.
Mar 05, 2014 | Home
How do you remove the battery from a 1992 corvette
Access is by removal of the exterior side panel. There are two 10mm bolts on top and bottom of the panel, the top needs to be removed, the bottom just loosened. There are 3 Torx screws inside the wheel well, difficult to remove with the tire in place unless you turn the steering to a stop, or use a Torx bit in a wrench. Bolt securing the battery on its base facing the driver seat needs to be removed.
Feb 28, 2011 | 1992 Chevrolet Corvette
Driver seat removal 1993 lexus gs 300
put the seat in the full back position remove the two front bolts securing it to the floor, move it all the way forward now, remove the two rear bolts securing it to the floor now tip the seat back allowing it to rest on the back seat. make sure there is no additional wiring plugged in. use the recline function the make the seat flatter, now with two people roll the seat and remove throught the front door utilizing the rear for the helper
Feb 27, 2011 | Lexus GS 300 Cars & Trucks
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
Question about the base to a car seat
What make and model is your seat? Look in the instruction booklet to see if you can use it without the base - you probably can, but the instructions are the final authority. If you don't have it, check the manufacturer's website for a download, or a 1-800 number to call to request it - you really should have it for reference.
For infant seats, extra bases are usually available: people with two cars like to put a base in each car so they don't have to keep re-installing it. Again, check the manufacturer's website.
Mar 24, 2010 | Baby Gear
My rear facing infant car seat tips over. My car is a 2000 Toyota Camry without the lower latch in the seat. The seat belt gives a little but locks in an emergency. The baby is not yet 20 lbs.
if it is an infant seat with a base, and can be used without the base, I suggest using it that way. We had the same problem with our daughter's car seat. sometimes those bases just aren't stable enough. Sits much more secure if you can use it without them.
Jul 16, 2009 | Baby Gear
Car seat without base
You cannot use a Peg Perego Infant Seat without the base. There is no belt path on the seat itself.
Mar 25, 2009 | Peg Perego Baby Gear
Seat Belt repair/replace
  1. Remove front seat.
  2. Remove adjuster cover. A
  3. Slide floor anchor cover.
  4. Remove floor anchor bolt. B
  5. Remove shoulder anchor bolt. C
  6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
  7. Disconnect seat belt pre-tensioner connector.
  8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
  9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
Nov 03, 2008 | 2000 Nissan Maxima
Installing into a Honda Passport
If this seat has the areas for a regular seat belt to go thru, you could use that belt to install it. Every seat belt if you pull it out all the way, and then start retracting it, it because super tight and cannot be pulled out again, until its been retracted in almost all the way. Be sure when doing this you get the seat belt as tight as possible. I like to put my knee into the car seat and press as hard as I can as I pull on the seat belt to tighten it.
Apr 09, 2007 | Cosco Summit High Back 22-260
MIA Moda Viva Infant Car Seat - Flame Logo
128 people viewed this question
Top MIA Baby Gear Experts
Dorel UK
Dorel UK
Are you a MIA Baby Gear Expert? Answer questions, earn points and help others
