Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio 50 inch plasma -- remote not working
I changed the battery (bought new TV 2 months ago) but it still doesn't work. The TV set works fine if I manually turn on / off. Any idea what's going on?
  • 5 more comments
  • Anonymous Apr 10, 2008
    Vizio VW42L is not responding to any remotes usually the cable remote shuts off the tv but neither remotes commands are working.
  • coandy Apr 27, 2008
    my vizio 47 inch plasma works intermittently and sometimes doesn't work at all. I tried switching of the TV and trying it again. Sometimes it work sometime doesn't.
  • at26 Mar 09, 2009
    In my case i dont think is the remote, because i have 2 other remotes  that  always work good with this TV, and non of them are working at this time. There's something wrong "inside the box".  Any Idea of what to do?
  • blue4_u2 May 12, 2009
    My vizio 22' is 6 months old, my problem is the remote,it works when it feels like it, when i use it, it work for a short time, but next moment it's acting crazy, when i push the vol, the channel may change, when i push the channel button the vol display will appear. but wont go up or down. and when i try to turn it off, it wont go off.
  • mmacys5 May 18, 2009
    Same problem... TV does not respond to remote at all.
  • garbear_99 May 01, 2014
    i have recently been the recipritant of the same problem with the remote. I have since, while trying to fix that problem, I ended up setting the tv in store demo mode. After hours on the phone with VIZIO and one of their outsource repair contractors, I took the remote to BEst Buy and found the remote was fine. So at this point looking at a IR sensor needs replacing to fix the remote problem, I hope that I can re-set the set to home mode.. smh..
  • Anonymous Sep 15, 2017
    Your idea worked like a charm.
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Posted on Jan 18, 2010
  • ROBERT BARTOLOTTA Sep 15, 2017
    Thanks to sChadwell for his resourceful help. I took the batteries out of the remotes and pressed all of the buttons up and down and VIOLA!, everything worked liked normal. I work in electronics and remember years ago that Microprocessors have little nervous break downs and that, If you unplug and go over the controls of what ever it is you are try to fix;THIS IDEA WORKS!!!!Thanks for your input as you reminded me of something I had forgotten Years ago.
Our Vizio remote control quit working properly - only certain buttons would work. I replaced the batteries and nothing changed. My husband took the batteries out completely and left them out overnight. When he put the batteries back in the remote control was back to its old self and has been working fine ever since. Try this.
Posted on Sep 15, 2009
Reset the remote control and the TV at the same time and this may work. Step 1; First unplug the TV from the wall/surge protector. Wait 5 Min. while your wait here is step 2; You take the batteries out of the remote>then press down on every button 2 Times>replace the batteries in the remote, after the 5min. go ahead and plug the TV in and try it again. If this does not work then you need a new remote control.
Posted on Sep 22, 2007
I have the same problem. Is it interesting to have a good tv with bad remote?
Posted on Jul 01, 2008
2 Suggested Answers
SOURCE:
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
Our remote died to our Vizio ....checked batteries, etc...have been having problems for a while...bought a new universal Vizio remote...keyed in all the numbers....last four work...but still is not...
New TVs and older ones, even recent model changes usually have different codes. Read the new remote closely. there is a section about finding the code manually. It is a pain, but works.
May 30, 2017 | Televison & Video
I bought a brand new 42 inch plasma vi vo tv 2
New products do fail. The set should certainly be under warranty. I would speak to the dealer you purchased the unit from and see what they suggest. Don't remove the rear cover, or do anything else to give anyone a reason to void your warranty. Most brands are 90 days on parts and labor.
Nov 25, 2009 | Televison & Video
My remote will not work
Dessasembly the remote control:
1.Clean,use the izopropilic alcool or 75%alcool or finest wisky the remote taste rubber pad.
2.Assembly the remote control,change the batteries(see the polarity).
3.Near on functional in the FM or MW radio (the distance to remote and speakerphone max.10cm) press any buttons to the remote control.If you can hear the emitent signal in the speakerphone ,the remote is work.
4.Try the remote to TV.If work is OK,if not change the infra LED.
The solutions is work 100%,I tested 25 years ago.
Sep 07, 2009 | Vizio VX32L Television
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
10,672 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
