Question about Teac DV-H350 DVD Player
Dvd player won't power up
When I hit the power button it will only blink on, and then goes back to rest mode. I've tried unplugging it in hopes that it would reset- but nothing changes. any suggestions?
  • harveyj Nov 02, 2007
    I have a similar problem with a TEAC AG-H500 receiver. The power led on the main swith goes out so there is no standby and the Radio station presets are all lost. It will however come back on if I first unplug and then re-plug it in.
  • 372 Answers
Hi. In most cases the reason you get this problem on DVD players, Vcrs, Cable boxes is down to electrolytic capacitors in the power supply. Look for any caps that are bulging or may have wet stain on the circuit at the bottom of them. Any bulging or leaky caps will need replacing. Im not familiar with this machine so sorry I cant give you position numbers.
Posted on Sep 14, 2007
SOURCE:
Panasonic 1080p DVD Recorder flashes "Hello" cannot turn off, eject DVD, play or anything
I just had this problem the other day. Unplug the unit for 2 minutes. When you plug it back in and get a the 000 press the power button for about 5 seconds and that will put it back in stand by mode. Hit the DVD open button instead of the power button. Hope this helps
Aug 03, 2015 | Panasonic Televison & Video
Computer Won't Let Me Past Disc Check?
if you have any external devices plugged in such as mice or hard drive or usb unplug them and then try to reboot. check online for the brand name of your computer for "safe Mode" typically its hitting the F buttons or the delete button and going into safe mode then if it will save the file you really need. then try to reboot
Nov 12, 2017 | Dell Computers & Internet
Dvd's won't come out of player
Try unplugging the dvd player, wait a few moments then plug it back in and hit the eject button, sometimes that works.
I’m happy to assist further over the phone at https://www.6ya.com/expert/keiffur_8e1bc404fbfd9eda
Oct 12, 2012 | LG RH177 DVD Recorder/HDD Recorder
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Teac DV-H350 DVD Player Logo
728 people viewed this question
Top Teac Televison & Video Experts
Steve Allison
Steve Allison
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
