Question about Ricoh Aficio 1013F Copier
Aficio Copier 1013 light on to load paper ( paper is loaded)
Our Aficio Copier has been jamming on a regular basis. Now it is showing that the paper needs to be loaded and there is paper in it.
Is there something basic I can do to fix this?
  • annaf1 Apr 16, 2009
    Thank you so much for the help!
  • 227 Answers
Check the paper end sensor, remove the tray, look inside of opening, at the top toward the right side, make sure there is an arm sticking down, wires are connected and the sensor is in place. Most common problem is the arm is dislocated or sensor out of position, See graphic Aficio Copier 1013 light on to load paper ( paper  - 91009d0.jpg
Posted on Apr 15, 2009
  • Arthur Hoffmann
    Arthur Hoffmann Apr 16, 2009
    Your welcome!
    Glad I could be of help
I have a problem in my ricoh aficio 1013, there is no prints on the paper coming out
try to check if the cam gear is still there,you can found it at the rear side of the pcu assy.
Sep 20, 2011 | Ricoh Aficio 150 Copier
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
The copier is jammed - the copy light and load paper light is on and I can not get the copier to reset.
Have you removed the paper tray to see if there is a piece of paper behind the tray ? Paper will frequently go behind the tray and wind up in the size switches and or the tray lift gears.
I would check that first. Let me know.
Aug 11, 2010 | Ricoh Aficio 1515 Black and White Copier
Aficio 1013f scan? How to scan documents and than save it on my pc or send them via mail? I need help because my aficio have italian titles on it.
This is a loaded question. the 1013 can be either a network scanner (nic) or a twain scanner. this will depend on the type of hardware interface that is on your machine. Network scanning is the preferred method. I noticed that your model is a1013f which leads me to believe that it may not be equipped with the scan hardware. You need to look at your control panel and verify the scan button is there
Oct 12, 2009 | Ricoh Aficio 1013F Copier
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Apr 10, 2009 | Ricoh Aficio 1013F Copier
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Printer says "load paper"
if you pull the paper tray all the way out and lift the tray slightly in the front it will pull out from the machine. look inside the ope area and you will see that the switch that registers paper is probably fallen out of place. Just super glue it back in and make sure the connector is reconnected.
Nov 26, 2008 | Ricoh Aficio 1013 All-In-One Laser Printer
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
