Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer runs but no air circulating
I have the same problem! No air circulating. I took my dryer apart and the heating coil is fine. My assumption is without the blower working the heating coil will not work. Before I replace the blower motor, how can I check the motor?
  • 207 Answers
Love2fix,
First use the dryers service mode and make sure that you are getting the same information as you suspect:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Best of luck!
Posted on Apr 16, 2009
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
Dryer got very hot when shut off,wouldn't heat up when running.
We took apart the dryer. the heating coil was broken in two. When the dryer was stopped it was not in off mode therefore the electricity was going through and the ends off the coil where it was broken was touching the metal and eating the dryer which made it hot to touch. We tested the 3 different fuses? the ohms were good. Ordered the part waiting to put it back together to be sure. Rule to remember even when dryer is stopped it should always be put in off mode.
Jun 02, 2009 | Frigidaire FSE748GF Dryer
Hello my Kenmore Dryer is working fine although taking alot longer to dry the clothes. I took everything apart and clean it, no vent blockage, and great air circulation through dryer. I was wondering; is...
THE ELEMENT CYCLES. NO IT DOESN'T STAY ON THE WHOLE TIME, BUT IT SHOULD BE ON FOR MORE THAN A BRIEF SECONDS TOO. POST ME THE MODEL NUMBER FOUND SOMWHERE AROUND THE DOOR AND I'LL HELP FURTHER. THERE ARE THERMOSTAT/S HIGH-LIMIT SHUT OFF SWITCHES AND IF THEY ARE NOT FUNCTIONING PROPERLY IT WILL CAUSE DRYING TIME PROBLEMS
Apr 11, 2009 | Dryers
Heating
The most common cause of heater failure is the thermal cutout/thermal fuse/temperature cutout(any of a dozen names for the same thing from different manufacturers) a device on the exhaust ducting near the fan housing. on over temperature, when the air temperature is hotter than the normal range set by the thermostats, these units melt out,
they are not resettable, they are replaced, ~$8 each, except where manufacturers are gouging
they look usually like this 2543d18.jpg or this d733938.jpg conduction good, open circuit fail
common to many dryer models the local parts guy will have them to suit, even if they are labelled with a different make or model
Oct 05, 2008 | GE DBSR453EBWW Electric Dryer
Heat to start, then no heat..
replace both coils on gas valve ..those are the blacks things with wires attached they are bad for not pulling valve oper=n after warm up
Jul 02, 2008 | Roper RGX4634KQ Gas Dryer
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
152 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
