Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Need a Service Manual to Change Pump & Impelleor ???
I am trying to source a Service manual for my Zanussi ZDT6252 Dishwasher....Please advise where I can obtain such a publication.... Thanks for ALL your Help. The Prof..
  • Peter O'Reilly Aug 11, 2009
    Hello Paul and thank you for your response...HOWEVER...it is a SERVICE Manual that I require and NOT the general User/Install Guide...
    Thank you for your kind response anyway...
    Best Regards,
    The Prof...
  • paulelliott1 Aug 11, 2009
    I was wondering if you could help me, I take it if you are looking for a service manual you are more experienced with dishwashers etc than the average guy. My zanussi runs on its programme for 1 minute then stops and flashes the first light (its the rinse and hold light)
    Someone here mentioned I needed to reset the computer / controller
    Have you any advice
    Thought it was worth a try
    Cheers
    Paul
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
My the dishwasher will not drain. The pipes are not blocked or kinked. If I shake the pipe the dishwasher will drain. But I cant do that all the time. Any suggestions?
Hi..
If your dishwasher will not draining you need to check this
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good luck !!!
Regards
PCmania
Jul 13, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 fills with water when not in use
Sounds like you have a leaking inlet valve. The best option is to replace it with a new one. It does have overfill protection on it but this may not work if its leaking.
Nov 13, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi ZDT6252 Levelling
After having the same problem I resorted to sawing off the rear foot, only to then discover that there is a crosspoint screw on the middle at the fron that winds up or down the rear foot.
Nov 03, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
342 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
