Question about Texas Instruments TI-84 Plus Calculator
T.I 84 Plus Calculator
When powered on, the LCD screen is dark blue. Will not accept or show any entries. Occasionally after calculator has been off for a period of days or weeks, will work properly for a few minutes. If left on, LCD screen turns dark blue. Successive power ups will yield the dark blue screen. Have tried replacing with known good/new batteries.
  • 3 more comments
  • kdh08 Apr 13, 2008
    The characters entered are displaying in the middle of the screen and are not showing properly. I have replaced the AAA and backup batteries to no avail
  • mannilechic Apr 17, 2008
    Dark blue screen, with a clear **** in the middle. I've tried adjusting the brightness and I can see the change in the dark ****, so its not the brightness. I've changed the batteries and left it alone for weeks. No change. Please help.
  • Anonymous Nov 02, 2008
    MY CALCULATOR WAS TURNING ON BECAUSE I COULD SEE A SLIGHT CHANGE IN THE BRIGHTNESS. BUT I CHANGED THE BATTERIES AND NOW IT WONT DO ANYTHING.
  • delitefuljam Feb 05, 2009
    My batteries eroded in my calculator. I had lost it for a while and I just found it. I remembered it did state that the batteries needed to be replaced when I lost it like a year ago. So I cleaned the acid off the batteries case with a damp paper towel and replaced the four AAA batteries and it still doesn't work what should I do?
  • madhavivemur Apr 01, 2009
    my son dropped his TI-84 Plus SE and the screen cracked.
Well, this might not be right, but check the Brightness. Hit 2nd, then the down arrow. repeat this a few times. see if that works.
Posted on Oct 10, 2007
The screen is cracked or broken. you dropped it or applied too much pressure on it. nothing u can do.
Posted on Oct 15, 2008
How to fix the mario game
Posted on Oct 07, 2008
Crack it open and see if the batteries have leaked and eroded the circuit board with acid.
Posted on Mar 30, 2008
My ti-84 calculator show unreadable code only?
Honestly, I do not understand what you mean. This calculator is designed to run commands one after the other. You may stack a few of them only if you do not need the output of the first ones.
Anyway, the memory is limited and that includes the register where the current line is stored. If you enter too many characters, the calculator stops accepting them and the cursor will change shape.
If memory is full you can no longer do anything. One simple way to regain some working memory (RAM) is to clear entries (the commands you typed). Press [2nd] [+] to enter memory managem2nt and select the command ClearEntries. You can also select ClearAllLists, or Reset. For the last choice you can then choose to reset ALL RAM.
Apr 28, 2012 | Texas Instruments TI-84 Plus Silver...
Upper half oc the screen on my TI- 84 calculator is blank
The Mode settings determine how entries are interpreted and how
answers are displayed on the TI-84 Plus. At first set option full screen and then folow next:If you cannot see anything on the screen, you may need to adjust the graphing TI 84 calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
Mar 22, 2012 | Texas Instruments TI-84 Plus Calculator
My calculator ti-84 plus is having problems. When i turn it on it will turn off quickly by itself. and while its on i try to click on any botton and it doesnt show the number etc
It could be that the main batteries are drained and are no longer able to supply power to the calculator. Replace the AA batteries with a fresh set. After replacing the batteries the display may become too dark or too dim. To set the correct contrast
Press [2nd] key and release it.
Press and maintain pressure on UpArrow to increase contrast (darken screen), OR on DownArrow to decrease it (lighten screen). If you overshoot your intented contrast you can revert the processs.
Aug 22, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84 plus calculator - broken LCD screen -- user replaceable?
The lcd is connected to a PCB with a driver, you can unsolder the LCD pins from the driver board. I think you are able to unsolder the entire board+LCD from the main calculator board, but I haven't tried that.
Your best bet at finding a new LCD would be to buy broken calculators off of ebay.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
My calculator isn't working
would you like to sell it? I am modding one for a computer/projector interface for my professor.
just reply to this forum if you accept.
Nov 04, 2009 | Texas Instruments TI-84 Plus Calculator
When I connect my calculator to the overhead, the display is dark and will not show the proper display that is on the calculator...is there a setting I need to change?
On the TI overhead screen, there is a dial. This is how you adjust the contrast. It sound like the contrast on the overhead display is too dark.
Aug 28, 2009 | Texas Instruments TI-84 Plus Calculator
Dark screen on my TI-84 plus. What to do?
Press the 2nd key (yellow one) and then press the UP arrow to increase brightness or down to decrease but seems like you to need to press UP arrow.
Jul 04, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
2,666 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
