Question about Kitchen Ranges
Light in oven keeps coming on
My oven light keeps coming on. It goes off if I press in on the door real hard but it's a continuing issue. Can this be fixed? Is it a defect or is there something I can do. This oven is only a few months old and has done this the whole time.
  • McCher Apr 15, 2009
    Thanks.....that looks like something I just should call a technician for as my range is very tightly placed in my kitchen and hard to move in and out from the wall.
  • 234 Answers
I believe that the switch is either defective or it is coming loose from its mount.
You will either need to make sure that the switch is properly fixed in place or replace the switch.
Depending on which particular oven you have, it could be more work than you would like to do yourself.
Your oven is probably under warranty and may be serviced free.
There may also be a screw next to the button that you could tighten and it will work. (hopefully it is this easy)
Be careful in removing switch if you do not disconnect power supply/plug.
Posted on Apr 15, 2009
Oven light stays on and oven is inop on Kitchenaid KGSS907SSS01. Tried to go to self clean mode, Display states close door, but door is close.
I suspect the door/light switch has malfunction. Look for a plunger type of switch and press it in and see if light goes out. If light goes out, close door and gently press on door and see if light goes out. If this happens, I think the door hinges are not closing the door 100% so the door switch is not engaged. Now if door light stays on while pressing door switch, then the door switch might be your issue. Good Luck
Sep 27, 2017 | KitchenAid Kitchen Ranges
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
Oven lock motor frigidaire stove close and open continuously- flashing door lock light
Hi Chris -- if I am understanding you correctly, your door lock is stuck with the door open. If this is the case, locate the oven door light switch that is typically in the top left corner of the unit. Press and hold the switch button in for about 30-60 seconds. While you're doing so, look for a flashing light on the control panel next to the word, "lock". If the latch hook is in the locked position, continue holding the button and press the CLEAR/OFF key on the control panel. Hold the button in until the flashing light goes off. If this does not resolve the issue, please supply your unit's model number and any additional symptoms it was experiencing prior to this event so that I can be of more assistance to you. - Best of Luck!
Aug 27, 2012 | Frigidaire Ovens
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
HOtpoint Electric stove/oven
You have not responded to my clarification request, so I'm guessing that you have resolved this issue. If not, let me know if I can still be of assistance.
Aug 26, 2008 | Hotpoint RGB745 Gas Kitchen Range
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
