I have an am62 that has a lot of 60 cycleish buzz. Moving the 6 pin mic cable effects the amount of buzz greatly and it is often possible to fiddle around with this cable placement until the buzz is gone. However this is not an a great way to work "next take please don't move and hold the mic cable just above your right eye brow ok?"
It seems like a grounding issue to me but I have not been able to solve it. Any help would be great
thanks
patrick
Comments:
Apr 15, 2009
- Yes I think so too but I have not been able to solve the problem. I have tried disconnecting the grounds and reconnecting them this seems to have no bearing on the buss. Also tried testing the grounds for conductivity and they all seemed to be fine.
also
I found that pluging directly into an m-box totally eliminates the buzz but going
through any other pre amp (sytek, api, neve, summit audio) and or
anyother digi interface 002 or HD yeild tons of buzz.
any thoughts? and or advice on how to trouble shoot this issue?
This could either be in the connector at the end, or the cord itself.
Comments:
Apr 15, 2009
- If you can find a problem at the connector itself, then you might consider shortening the wire on the bad end and resoldering it to the connector. With any luck you will cut out the bad spot.
microphone of our ew100 failed due to stress at plug head. My attempt at repair has not worked. The...
(More)
microphone of our ew100 failed due to stress at plug head. My attempt at repair has not worked. The very fine copper line, as well as the shielded core may have defeated my attempt. Sennheiser will no longer services G1 product, and only suggests upgrading to G2. This system worked perfectly for years, and I do not want to have to replace anything due to a simple wiring/connection issue.
bodypack sends no signal, turn switch next to battery from inst to mic, and back, starts to work,...
(More)
bodypack sends no signal, turn switch next to battery from inst to mic, and back, starts to work, bump or wiggle cord in guitar, goes out again, whats' up? just the cord? or maybe body pack? Thanks
i'm having trouble with the line in on the mic using my acoustic guitar pickup. THe mic picks it up...
(More)
i'm having trouble with the line in on the mic using my acoustic guitar pickup. THe mic picks it up but i want to see if it has less white nose through the line in option but it is not being recognized!!! what do i do?
Fender Passport PD-250: The PA works great in single channel whether it's an IPOD or guitar. Once we...
(More)
Fender Passport PD-250: The PA works great in single channel whether it's an IPOD or guitar. Once we play guitar and sing at the same time the PA clips or loses signal strength. Any idea what's causing this? Thank you Douglas
