Question about Sharp AR-168D Black and White Copier
Display says Maintenance Required call for Service
Was printing fiine but is now starting to print lighter
  • 227 Answers
Sounds as if you need a Preventative Maint. Light print=(most commonly) the Developer is worn out, or Photo Conductor needs to be changed
Posted on Apr 15, 2009
Testimonial: "Developer was indeed bad and the service counter needed to be reset. Bought a service manual and it showed how to do both. Thanks"
How do I set it to draft
Go to the printer settings and have a look in there. The settings may be found on the printer itself if it has some kind of digital display, but more commonly it will be in your computer somewhere in Settings>Devices>Printer. Look for a setting like "print properties" and uncheck the "draft" setting to put it to normal printing. This may darken your printing. If it is not set to draft then set draft and see if it comes out lighter, and if it does then it may be an ink issue and you may need to clean the print head. This will be somewhere in the "Print Maintenance", again somewhere within the settings.
I hope that helps.
Mar 04, 2016 | Office Equipment & Supplies
Pitney Bowes E700 doesn't print at all althougth the mechanism appears to be working fine. I've changed the cartridge and cleaned the print head and run maintenance several times but to no av
Addressing Original Question: Its essential that the PB E700 machine is linked to Pitney Bowes account to either a) add postage or, b) carry out an Inspection. within 90 days or machine will start flashing "Inspection Due" if this is ignored after a further 30 days the machine will start flashing "Inspection Required" and stop printing! Perhaps this is the solution required.
a) First Connect machine to telephone line as if you were going to top up with postage.
b) Press "Refill"
c) Press "0"
d) Press "Enter"
Machine should display your current balance with PB.
And the Inspection message will be cleared.
Hope that helps. I also misunderstood the "Inspection" message thinking it was referring to a maintenance requirement, when it is actually an antifraud/security requirement of the postal authorities to check location and usage of the machine.
Mar 07, 2012 | Office Equipment & Supplies
Our copier were printing fine and then all of a sudden the copies started coming out very light. It isn't a toner issue because we replaced it with a new one and even tested it with another new one....
It sounds like you need to do preventive maintenance ( cleaning of laser unit, copy optics, replace transfer and everything that is in HP PM KIT )
Call service!
Sep 09, 2011 | HP LaserJet 8000n Printer
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
EPSON PRINTERM SERVICE REQUIRED WHEN PRINTING
Find SSC utility or adjusment program refer to your printer type. Try find at indoreset.blogspot.com. Or contact me for free resetter an instruction detail.
Oct 08, 2009 | Epson Office Equipment & Supplies
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
How to get the copy counter on the display?
Press the stop/reset key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/reset key. entering service mode.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys
enter 000 start to print staus report.
Do not change any settings...only use 000 to print report, then 001 to exit service mode after it has finished printing.
This is very important so that you dont render your machine useless.
To exit service mode-
Enter 001 using the copy exposure
+/- keys, and press the start key.
Jun 05, 2009 | Kyocera KM-1505 Copier
Poor colour
1. Ensure that the printer is powered on.
2. Press the <Menu> button.
3. Use the [<] or [>] cursor button to select 'Maintenance/settings', then press the <OK> button.
4. Use the [<] or [>] cursor button to select 'Maintenance', then press the <OK> button.
How to print a nozzle check pattern
1. Extend the paper output tray. (Confirm that the paper thickness lever is set to the left.)
2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder.
3. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
4. Use the <up / down > cursor button to select NOZZLE CHECK and press the <OK> button.
5. Use the <up / down> cursor button to select Yes, then press the <OK> button. The nozzle check pattern is printed.
6. Confirm the nozzle check pattern.
The normal nozzle check pattern
The abnormal nozzle check pattern
White lines are present ,black and/or color inks are not present.
- When all patterns are printed normally, press the <up / down> cursor button to select 'All A' and press the <OK> button.
- When any patterns are printed abnormally, press the <up / down> cursor button to select 'Also B' and press the <OK> button.
Top of Page
How to do print head cleaning
Note: Cleaning the print head consumes a certain amount of ink.
1. Display theMAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down > cursor button to select CLEANING and press the <OK> button.
3.Use the <up / down> cursor button to select 'Yes', then press the OK button to start print head cleaning.
Note: Do not do any other operations until cleaning is completed.
4. Print the nozzle check pattern and check the print head status. (See How to print a nozzle check pattern above.)
Top of Page
How to do print head deep cleaning
Note: Print head deep cleaning consumes more ink than print head cleaning.
Perform this procedure only when print head cleaning cannot resolve the print problem.
1. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down> cursor button to select DEEP CLEANING and press the <OK> button.
3. Use the <up / down> cursor button to select 'Yes', then press the <OK> button to start print head deep cleaning.
Note: Do not do any other operations until deep cleaning is completed.
Note: If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. After a given time interval, ink could dissolve itself, resulting in ink unclogging.
When the printed result does not improve even after these steps, replacement of ink cartridges may be required.
Nov 14, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Sharp AR-168D Black and White Copier Logo
424 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
