Question about Toshiba Televison & Video
My toshiba big screen will not power up. power light flashes like an auto turn signal.
    Champion:
  • 230 Answers
Verical Ic , and capacitor 100 35V, 220 35V and 3300 35 V
Posted on Apr 15, 2009
Toshiba big screen tv black screen with sound
It is telling you that you need a new backlamp or that the power supply that feeds it is out. It could be bad Chinese capacitors or you may actually need a back lamp. The hint was when it was working did the side edges have a darker brightness to them? If yest the lamp is needed. If no then the capacitors in the backlamp supply may have decayed.
Oct 01, 2012 | Toshiba Televison & Video
Hello. We were hoping that you can help. We have a Toshiba LCD, 40G300U3. When we turn the power on, the green power light turns on and we can hear sound coming from the speakers ... however the screen...
Take a flash light into a dark room with your laptop, and shine it into the screen when it is on. If you can see the screen then more than likely your back light is out.
If you do not see an image with the flash light, then more than likely your motherboard or LCD is going bad, this needs to be tested by a computer profession to see which is going bad.
Jul 17, 2011 | Toshiba Televison & Video
Toshiba 26AV600T When turn off by remote control ( stand by lamp still illuminate) I can not turn on by remote ( ON/OFF in the same button ) Q: TV set OR remote is bad. Thank you /// Thongsuk. My Mail:...
Tries the tv manual control power button pushes a couple of times on/off,if tv it turn on and off with no problems.Yes.Than the tv remote have problems.Try Remotes.com to buy the original remote.
Jul 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
My Toshiba flat screen won't turn on with the remote control. There's a red light showing but no reaction. I have checked the batteries and put in new ones, definitely the right way round. Is...
Can you turn the TV usin g the power switch on the TV?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.remotecontrolscenter.com
http://www.newremotecontrol.com/
http://www.replacementremotes.com
http://www.newtvremotes.com
http://www.everytvremote.com/
Jul 01, 2011 | Toshiba Televison & Video
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Toshiba tv
Is the red light flashing or solid?
If the red light is flashing it is the signal board is bad part number 75001688 $425.00 - $475.00 depending on supplier.
If the red light is solid then you signal cable has come loose or has went bad.
Sep 10, 2008 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
I have a 50" big screen tv by toshiba. I need a replacement protective screen or a place I can get it.
Aug 26, 2008 | Televison & Video
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Televison & Video Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
