Question about Ariston Technologies Dishwashers
Ariston LS2020 stops in the middle of the program. Water leaks.
Product: Ariston Technologies LS2020 dishwasher.
Ocationally the program stop in the middle of the washing cycle.
The bottom plate fills with water and leaks on the floor.
If the water on the bottom plate is removed (with a rag or sucked away) and the program is pushed one step forward it continues and the sound in the pump can be heard.
Then the program continues to the end.
  • 10,515 Answers
Hi bjornkr,
  This is due to defective gasket.
check the below link for detailed procedure :-
http://www.ehow.com/how_112279_fix-leaky-dishwasher.html
Thanks for using Fixya.
 Do rate the solution.
Posted on Apr 15, 2009
L 63 B NA Ariston
Your dishwasher is equipped with a safety system which is able to
detect any operating anomalies. These anomalies are reported by
one or two wash cycle indicator lights "G" flashing rapidly.
24238319-0h3kxpflbez5mdeb5anq3st4-3-0.jpg In this case could be:
  • Drain motor disabled
  • Filters clogged
  • Drain hose blocked
Dado
Apr 24, 2014 | Ariston Technologies Dishwashers
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Our hot water heater has stopped working in our Ariston dishwasher. How do I order a new part?
You need to take the bottom front off the heater, UNPLUG dishwassher first. There will be two wires going to the heater element, Unplug one wire and check the element with a OHM meter to see if the element is bad. If you don't get a reading the element is bad write down the make and model number you can order this part from sears or a local appliance repair parts store.
Feb 16, 2010 | Ariston Technologies L63 Free-Standing...
Our hotpoint bf168 has stopped working. The rinse
Petere
Did you have ny luck solving your problem as my dishwasher has the same error
Lorraine
Jan 11, 2010 | Ariston Technologies Dishwashers
Ariston ls1072. water going straight through the system. seems a valve is not operating.
sounds loke the drain is lower than the machine, is it new install or been moved recently? try raising the drain hose middle section a foot or two above the ground.
Jul 23, 2009 | Ariston Technologies Dishwashers
Ariston ls2020 dishwasher dishwasher will not fill with water
anti flood device has been activated on inlet valve so appliance will not accept water
Jun 25, 2008 | Dishwashers
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
106 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
