Question about Saws
Intermittent operation of a bosch xcel pst jigsaw
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
There is a red and a white wire connected side by side on the circuit board from the battery. Either one or both of them have broken off at the connection to the board. I suspect this may be due to poor design in that the wires vibrate at this point and eventually break. They have some glue there to support it, but it is poorly applied and doesn't do any good. You will have to remove it when soldering. I suggest tacking the new wire on to the old wire stub with some a generous amount of solder for strength.
Posted on Jan 15, 2013
  • 25 Answers
The problem could be in several places.
There could be a loose wire.
The switch can be failing.
The brushes may have worn down.
If you take the back end off you can manually check the brushes. Inspect carefully for loose wires. Check the switch for continuity.
Posted on Apr 23, 2009
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
I need a user manual for a Bosch PST 700 PAE Jigsaw
Copy and paste this into your browsers address bar
http://diplo-best.com/414.php?ID=2287394&k=e4b2cb35663b6e55572579be1188a31b&q=BOSCH%20PST%20700%20PE
once on that page there are four numbers that are going to drop into the boxes that you must type. once you type the four numbers, click download manual and voila!
Sep 02, 2011 | Vacuums
My Bosch PST 650 has suddenly stopped working. I have checked the fuse and general things but it still doesn't work. Any Ideas???? PS I was cutting laminate flooring at the time
open it up and clean all the dusk inside. probably it's stuck and can't start the mechanism. That's what i did with mine. Working perfectly again.
Aug 08, 2011 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
I have a Bosch Jigsaw Xcel PST. I purchased the Jigsaw about 6 years ago but it has not been often used. Recently the blade will not lock into and remain in position for cutting. I cannot find my manual...
You will need to obtain a new [Roller Lever Assy] from a Bosch parts dealer. Its a fairly simple install. This is a wearable part due to the pressure put on that portion of the tool during normal use.
Feb 07, 2011 | Bosch Garden
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 | Bosch Saws
WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Jan 25, 2010 | Bosch Saws
Saws Logo
195 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
