Question about Maytag MAH6700AWW Neptune Front-Load Washer
Motor control board needs replacing
I need to replace the motor control board per the tech who just diagnosed the problem. What info do I need to get the right board and where is the best place to buy it?
  • Michael Masters
    Michael Masters May 11, 2010
    These are the control boards on your machine(ECA-Electronic control assembly,PCB Mems, and PCB Assy-6). that's it. no motor control.
  • Michael Masters
    This front loader dose not have a Motor control board. it has an electronic central control board that controls everything. Are you referring to this??
  • 242 Answers
You need to get the model number off the door jam or from the back control panel to order the correct board.
Looks like the right one to me you have listed already , once you get the part number for the actual motor board then you can search on line for the best price on one.
Phil
Posted on Apr 15, 2009
Wipers work only on high on 2013 Toyota Tun
Gerald, Could not find a lot of info. on the net to your Tundras problem. Sounds like the wipers have a faulty wiper motor control/resistor/circuit board/switch. You may have to take it in and have a good Tech. diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windshield Wipers Only Work on High Speed eHow
2014 Toyota tacoma adding intermittent wipers
Jul 28, 2016 | Toyota Tundra Cars & Trucks
Can't control heat to glass top element frigidaire electric stove
sounds like you need a tech to visit, it may have something to do with electronic control circuitry that a familiar and qualified tech will be aware of. There may be a no answer beyond this for such an appliance
Apr 24, 2016 | Frigidaire Kitchen Ranges
After changing the cold water valve on a GW612 do I need to do a reset
The motor controller board could have a faulty water valve mosfet.
have part replaced by tech or replace motor controller board.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
My samsung fronload dryer will not spin. There is no error code. Someone came out and told me that I need a belt. The belt was replaced but the tech now says he
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace. .
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is esasy to replace .. To check this further you will need to refer to your tech sheet or service manual.
Oct 17, 2012 | Dryers
I have no power at the control board, no code is showing. Has 120V at the unit.
see this and replace if necessary. God bless you
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 27, 2012 | Samsung SM-DMR77LHS - SERVICE MANUAL
Need a control board for my treadmill
Dear Sir.
You must call some service tech, since that you have the motor burner and now the main motor board.
After that run the software calibration for easy diagnose and troubleshooting.
There some place where you get this parts and get help www. treadmilldoctor. com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 08, 2012 | Exercise & Fitness
Kitchenaid superba failure codes e1,f2, and door is locked
Hi Bill:
The E1F2 error code indicates replacing the board. It is in the realm of possibilities that your new board is defective. If I were certain the board was good I would focus my efforts on tracking down an electrical fault.
The likely failure is the control panel; however it could be the control board.
Since you did replace the control board already, the problem is most likley a key pad that is sticking.
I added a portion of the technical data sheet in the image below. You will need an ohm meter to be able to check the key pad operation. I added the information needed in the image below. If the control panel tests OK, replace the control board, if it fails, replace the control panel.You may need a hands on tech to run these tests and diagnose and repair your oven. Or just buy the key pad controls. Check THIS LINK.
Here are the parts
Replacement parts for WHIRLPOOL KEBS208DSS8 ' AppliancePartsPros.com
Here is a manual and a tech sheet
https://secured.whirlpool.com/Servic...all%20Oven.pdf
http://www.servicematters.com/docs/w...%204451879.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | KitchenAid KEBC208 Electric Double Oven
How can i fix the error code 3E> i am a mom and i
The 3E error code indicates a motor problem. If you have a volt/ohm meter and are comfortable working around live electricity I can give you a few checks that will help you diagnose the problem.
Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts. If you are not already sure you can perform these checks safely and competently, refer this work to a qualified professional. Working with live electrical current can be very hazardous and possibly deadly. Testing voltage output requires working with electrical current. Do not attempt these measurements without the proper tools and safeguards.
I have included a set of illustrated instructions (See below). These should step you through the process of disassembling your dryer and testing the motor. If the motor tests outside of the ranges listed, replace the motor. If the motor ohms correctly, replace the main control board. Note: If possible ohm the motor from the control board.
You probably fixed the problem by disconnecting and reconnecting the motor wire harness. The attached tech bulletin has more info on the E3 code.Attachment: TDL-0078-B.pdf (need register for free).
Additionally, this could helped, click image for zoom...
Hope helps.
Jul 09, 2011 | Maytag Dryers
My washer will not go to the spin cycle. the timer continues to run but the door lock releases and it will not spin. everything else works fine
On this model there could be several reasons why the washer will not go into the spin cycle. The most common problem is the machine control board not providing voltage to the door lock wax motor. This type of diagnosing will require accessing the console area & inspecting the machine control board resistors. I am sending you an image showing where on the control board to look. If the R11 resistor is burnt like I suspect then you will need to replace the door lock wax motor & machine control board. If this diagnosis does not help I am sending you a list of other possibilities. On this model you may consider calling a service tech out to diagnose & repair. Also if you need help with parts please send in the serial number. Please see the images provided in the attachment below for further instructions.
Jan 18, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore front load washer wont spin...
check the motor control board ,,, sound like thats what your looking at
Dec 08, 2008 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
205 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
