Question about Dishwashers
Frigiaire dishwasher upper spray arm cover came
Frigiaire dishwasher upper spray arm cover came off. Need instructions on how to put back on. Maybe visual instructions in addition?
  • Shirley Megason
    Shirley Megason Apr 16, 2009
    The upper spray arm came off my Frigidaire dishwasher. Just read this online and am going to go try it. Will let you know if it works. It said:
    On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
Okay, it worked! Reach up in the very top (inside) of dishwasher and unscrew the only thing up there that will unscrew. I just used my dishrag (remember righty-tighty and lefty-loosey). Mine had a small white ring laying in the indention that had 2 "teeth" pointing down. I turned the 2 white teeth crosswise to the two gray teeth in the top of my spray arm and it snapped right together. I then screwed the whole thing (with spray arm attached) back to the top of the dishwasher. I didn't have to worry about the above 'one tooth at a time' thing because mine only had 2 'teeth' and snapped back on easily. Yes, it's a little wobbly but it's always been that way. I always try to make sure nothing is hitting it but will be more careful. Good luck with yours. :)
Posted on Apr 16, 2009
Dishes are not getting clean. Dishwasher does not take off the smallest speck of food. Hot water works. Cycles sound the same
There could be a couple of things that might be affecting the cleaning ability of your dishwasher.
First,there is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My children used to put large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, it could be that the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Aug 14, 2011 | Frigidaire 24 in. PLD2850 Built-in...
Mod m.d.c.5100aww ser28126829ax I had a repairman come out. He said the "sprayers" are plugged. I'm on a fixed income. With my bills I can't afford to get it fixed. Trying to fix it myself. I...
Most dishwashers dispense the detergent via gravity and the sprayer arms spraying against the soap dispenser once the little door flips open during the wash cycle. Since it sounds like the soap door is opening I would look at the sprayer arms and make sure they are free of food particles or other debris that might be keeping them from rotating and spraying properly. Here are some instructions for performing this check.
Remove the lower dishrack from the unit. Reach into your dishwasher and spin the lower spray arm. Take note of whether or not the arm moves freely or if its movement is restricted. It should not be restricted in its path of motion. Now gently pull up on an end of the spray arm. The spray arm should be free to wobble up and down. Unscrew the arm retaining knob (some of these are left hand threads) and take the arm out for inspection and carefully examine the spray arm seams. If they have split or are damaged, the dishes may not receive the amount of water pressure required to fully clean the dishes or to rotate the arm properly. What’s more, if water is in fact spraying out of the spray arm from its seams, it is possible that it can cause your dishwasher to leak. Make sure there is no debris in any of the holes.
If your dishwasher has a spray tower, pull up on it as far as it will go and then let it fall back down. Again, this movement should not be restricted. It should be a fluid and smooth motion. Also, unscrew the spray tower and examine it for any debris or foreign objects. Remove any that you find.
Gain access to the upper spray arm by removing the upper dishrack. Perform the same tests for the upper spray arm as you just did for the lower spray arm. Keep in mind that the upper spray arm may not wobble as much as the lower spray arm.
On a final note, some dishwasher models have a water tube that meets up with the upper spray arm once the upper dishrack is pushed back. It is a good idea to check to make sure this tube is aligning properly with the upper spray arm and that this has not split or is damaged in any other way.
Mar 24, 2008 | Dishwashers
My kitchenaid dishwasher the water does not get to the upper rack...and the dishes on the second rack on not clean at all....
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
Jul 17, 2011 | KitchenAid Dishwashers
WONT SPRAY WATER. WATER SUPPLY OK
Jul 15, 2011 | Dishwashers
Water does not enter upper tier in my portable dishwasher
Jul 04, 2011 | Dishwashers
The top sprayer does not work
Jul 04, 2011 | Maytag Dishwasher
Dishes do not come clean
If not, then the upper or lower spray arms may have debris that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
The middle spray arm isn't rotating
Jul 04, 2011 | Frigidaire Dishwashers
Top rack - glasses etc... not getting clean - bottom rack and utensils seem fine?
Jul 02, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1145XTPQA - The Dishwasher runs its cycle properly, but the top rack looks like it didn't even get hit by water, often resulting in glasses and dishes being really greasy.
Jun 30, 2011 | Dishwashers
Dishwashers Logo
232 people viewed this question
Top Dishwashers Experts
Owen Barnes
