Question about Craftsman Garden
Broken pull cord
The pull cord broke on my weedeater and I cannot get to it to replace it anyideas?
5 Suggested Answers
  • 27 Answers
SOURCE: broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
Posted on May 31, 2009
panilling9
  • 284 Answers
SOURCE: Weedeater xt200 broken throttle lever
manddmower.com
part # will be 530038682
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
Posted on Jun 02, 2009
SOURCE: Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Posted on Aug 12, 2009
I have a cub cadet bc280 2cycle weedeater the pull string pulls but it want go back in need help please
un screw recoil cover and remove be careful because if spring is broke can cause it to pop out unexpectedly and spring is sharp check rope if off track use screw driver to reinsert and should wind back if rope broken will need to replace if spring or coiler damaged also need replacement
Aug 10, 2016 | Cub Cadet Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
I have a craftsman push weedeater and the pull cord broke and I want to know how to reinstall so the cord so it will work. I have taken the cover off and fixed the cord and put everything back together but...
you will need to pull the shroud back off, turn shroud upside down, wind it up and with a screwdriver or another pair of hands thread the cord back through, tie a knot and burn it, let go of the it, it will wind the cord back in, pull on it a few times and make sure it is working, then reinstall. Hope this helped Tim
Mar 12, 2011 | Garden
I have a Troy Bilt Weedeater Model # TB415CS Here is the problem my wife decided to use this unit while I was at work one day and broke it. When I go throught the start up routine and go to pull the start...
If the rope recoils back into the starter, at least the starter spring is not broken...but...if you can break the unit down to where you can get a good look at it, you may find that the ratchets on the starter pulley are not engaging with the pawls on the flywheel...The pawls are spring loaded so they engage and then drop out of the way when starting, See if you can break the machine down to that point and post back,
Aug 06, 2010 | Troy Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Aug 06, 2009 | Ryobi Garden
Broken pull cord
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Broken pull cord
Garden Logo
157 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
