Question about Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ... Mac Notebook
Mac notebook unable to connect to the internet wirelessly
We are only able to connect to internet if we are hooked up to the router. Unable to connect to the internet wirelessly. We have tried going to the airport and selecting our connection, but that dose not work.
  • 3 more comments
  • Anonymous Apr 17, 2009
    Wireless shows full connection yet no internet access
  • JDTec
    JDTec May 11, 2010
    What router do you have? Is it the Mac Airport?
    Or are you connecting to the router via the Airport adapter on the Macs?
  • JDTec
    JDTec May 11, 2010
    Do you have other computers that access the Airport ok?
    Have you tried resetting the Airport?
  • Sindre Rikheim May 11, 2010
    What kind of router is this? And have you managed to connect with a PC? Make sure you chose the correct Wireless Security when connecting. Is the router set up with a password? If so, it might require that you use WEP 40/128-bit hex password, or maybe regular WEP Password is enough.
  • ila wilde
    ila wilde Feb 04, 2014
    mine shows that it is connected, but it's not fully working.
  • 50 Answers
Go to network setting then assist me , select default location after completing it . go to advance setting then check dns server and add the server ip adress in it save the settings check it is working. rate if helpfull
Posted on Aug 12, 2009
Unable to connect to the access point
Hi tissa,
I see you are unable to connect to your Access Point as noted on the question provided.
First console cannot connect to an Access point if it is Password protected.
You will need to disable the Password or Network Access key from your Router to be able to get your DSi to connect to your Access Point freely.
To get security with your Nintendo DSi connecting to your Access Point in your Router setting you can enable the MAC Address filtering and get your devices MAC addresses and have it registered or input in your Routers MAC Address Filtering to be able to get your DSi connected wireless and at the same time have your Laptops and other wireless devices connected.
for the MAC address you can call you Internet Service provider on the issue to give you detailed info on how to access you Router settings for the said connection.
I hope that this will help.
Thank you fo choosing Fixya,
mvincentc
Jul 15, 2011 | Nintendo DSi White Console
Just got my EEE PC yesterday and I am unable to wirelessly connect to my router at home. I can connect to other wireless networks with the pc and my router works fine with with other wireless connections...
Have you put mac access control on your router, if so turn it off? is the router g or n or b compliant and does your pc match? have you set the right security wep/wpa/wpa2? if using wep you may need to not use the passcode but the key 1 which is generated from it.
Aug 28, 2010 | ASUS Eee 4G Notebook
I am unable to connect to the internet using a wireless connectio
I would first try and reset the router, then run a Repair on the connection again.
If this doesn't work, try going into the Device Manager and removing the Wireless Device. Restart the computer and reinstall the Wireless Device drivers.
Jan 26, 2010 | Intel S6240 Notebook
Unable to connect to internet . wireless connection shows connected at 150 mphs, using repair function seems to hang up at acquiring network address
The wireless access point may have MAC address filtering turned on. This means, that only explicitly allowed network devices can fully connect. This is used to prevent unwanted guests in your network.
You must ask the administrator of the access point or router to add you to the allowed MAC address list. If it's your router, go to configuration and check if the MAC(physical) address allow/deny list is active.
Oct 23, 2009 | ASUS Eee 4G Notebook
Unable to connect my g4 to the internet
Does your wireless router have wireless capability? If it does have wifi, you must configure the wireless settings on your airport to match the wireless settings of the router
Jun 11, 2009 | Trendware TRENDnet TW100 S4W1CA...
The IP address 192.168.0.1 you use with your browser is not to get into the Dlink WEB page, it is to get into the DLink router configuration, to set up the router and wireless security eg. network SSID, turn off SSID brocast, WEP/WAP encryption, MAC address filtering etc.
Apr 19, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
No internet connection
Some ISPs require you to register the MAC address of your network adapter before their DHCP server will issue you an IP address. The MAC address of the router is different than the MAC address of the NIC in your laptop. Call your ISP and they should be able to help you.
Jan 27, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ...  Mac Notebook Logo
249 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
