Question about Scunci 52001 Handheld Steam Vacuum
The brass nozzle is stuck. I already put some w40, but it doesn't seem to work. Can you suggest something else? Thank you
  • 1 more comment
  • csmsantana Apr 15, 2009
    I need to know how I can create the pressure to release the brass nozzle.
    I need to know how I can create the pressure to release the brass nozzle on my Scunci. The brass nozzle got stuck and it's not releasing steam.
    Do I put the whole thing in the freezer? won't it damage the unit?
  • 15,935 Answers
Empty out all the water and put it in the freezer for an hour or so.
The brass will shrink, allowing the nozzle to be removed.
Thanks for using FixYa.
Posted on Apr 15, 2009
  • blueextc3221
    blueextc3221 Apr 15, 2009
    not if all the water is out.
    A second option is to purchase a can of compressed air - and go against the directions and spray it upside down.
    This will release the cold difluoroethane directly on the brass and temporarily shrink it as well.
    I suppose you could try the fridge first - however it will take much longer... and wont shrink as much.
  • blueextc3221
    Here are a few other users solutions too...
    To remedy this, I did the following:
    1) Removed screws from:
    a) Lower area of handle (1 screw),
    b) Top of steamer, under round rubber flap around fill hole (2 screws),
    c) Front of steamer where nozzles attach (2 screws)
    2) Removed back of handle, top of steamer, front of steamer where nozzles attach
    3) Once all parts are removed, you can see a brass button that is pushed by the trigger
    4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
    5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
    6) Reassemble all parts (everything snaps back neatly into place).
    This worked for my unit!
    To fix the problem of no steam coming out or steam coming out without pushing the buttom.
    Do this:
    1. Remove the two screws from the from of the steamer then remove the end cap.
    2. Removed screw from the lower area of handle.
    3.Top of steamer, remove the two screws under round rubber flap around fill hole.
    4. Removed back of handle, top of steamer, front of steamer where nozzles attach.
    5. Remove the plastic tube where the steam comes out.
    6. Now look in the hole where the steam comes out and remove the 1/4 inch nut, metal washer, and rubber washer.
    7. Take a small punch and lightly tap the brass rod until it pops out the back.
    8. Remove the brass rod and spring. " The spring will have white crud on it and in the hole where it came out of. Clean the hole and spring realy good. This will fix the problem of steam always coming out with out pushing the button."
    9. Clean the brass rod, spring, and hole that they go into. I use a very small round wire brush. "Like the kind you might use to clean a gun."
    10. Spray some WD40 in the hole and on the brass rod, then put a few drops of oil on the rod.
    11. Put every thing back together and it will work like new.
    12. Don't use tap water in the steamer and you will not get the build up.
    mine did the same thing. i used vineger and clr and it still didn't work. my son came over and had a hard time figuring out why it didn't work because it was steaming great. he cut the black plastic with a knive right in front of the push valve out to release the push valve so it could be depressed more. and walla it worked!!!!!
    Hope one of these works for you!!
  • 10,515 Answers
Hi csmsantana,
All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions.
Thanks for using Fixya.
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
It's brand new - just out of the box! Noticed the dirty water tank is bone dry. There is no suction! The front removable nozzle seems to be loosely attached.. The metal clip doesn't seem to hold it...
It sounds as if it wasn't assembled correctly. Was it already put together when you purchased it? It sounds like the Brush Bar Belt never got put on.
Let me know if you need more help.
Jim
Oct 10, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Power nozzle N106M on our Electrolux Guardian has stopped workin
Start simplest always and work back to most difficult... so make sure you have power to the main unit, do you have a cheap voltmeter? If not they're cheap... Second check that connection plug is not stuffed with debris. Point is isolate whether it is the unit or attachment, most likely it's in the connection and repairable by you or used vacuum repair.
Aug 04, 2017 | Electrolux Guardian Bagged Canister Vacuum
Carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Jan 12, 2009 | Hoover S2220 Flair Bagless Upright Vacuum
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Apr 19, 2008 | Scunci 52001 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Scunci 52001 Handheld Steam Vacuum Logo
109 people viewed this question
Top Scunci Vacuums Experts
JoeVacs
Tom Chichester
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
