Question about HP Pavilion DV5-1000US Laptop
HP DV 1000 screen goes dark after boot up. Plug in external monitor and it works fine. Toggle between internal and external and I can get the laptop monitor to come back on for a few min. Turning brightness up or down makes no difference to timing before it goes dark again. Running on battery or pluggesd in no difference. Help!
    Scholar:
  • 54 Answers
Your laptop's monitor went bad and needs to be replaced. I had the same problem on an IBM laptop I had. Replacing the monitor costs between $120-220.
Posted on Apr 15, 2009
HP dv7 Display toggle problem
what PC full name? what OS?
so are you saying you want both screens the same time.?
the operators guide answer this.
dV7, what, you didnt post the full model. ,
lots of DV7 made. 1000 to 6000 series. sorry cant guess.
is sleep mode off
and screen saver off/ hibenate off.
id read the users guide first, see what options are featured, on YOUR PC. 29 classes of dv7 and subclasses.
https://support.hp.com/us-en/products/laptops/pavilion-notebooks
read your service tag to learn what you have.
then go here
WHAT OS came with your PC day1 new.,
is the current OS same as DAY1.? or upgraded some why..
if upgraded, to what?
all the 1000 series book says is this, "says it alternates"
page 17
http://h10032.www1.hp.com/ctg/Manual/c01492734
or ask on the real forum HP?
https://h30434.www3.hp.com/
Jul 01, 2017 | HP Pavilion Computers & Internet
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
Im trying to switch to an external monitor on my hp G60-235DX laptop. The laptop screen has been damaged and does not work. Is there an easy solution?
Try holding the 'fn' key and hitting f5 after the external monitor is connected.
This should toggle through the internal / external / both monitor selections.
Sep 12, 2011 | HP G60-235DX Notebook
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Hello, I have a problem with hp pavilion dv
Try lowering your display settings when it is hooked up to the external monitor. Then try the laptop screen again.
Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 13, 2009 | HP Pavilion dv6000z Notebook
HP G6000 laptop, screen completely green. top and bottom taskbars are black/ red flickering.
Seem like your video is going bad on the motherboard or your LCD screen. This is how you can determine which is going bad:
- Connect a monitor to the output and toggle Fn+F4 about 2-3 times or until you see video on both screens.
--If you have that same picture on the monitor then its the internal video....new motherboard needed.
--If you don't have that problem on the monitor then its with your LCD screen and it will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | HP Pavilion dv6000z Notebook
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
My power comes on my laptop but screen is dark
First, Plug in an external monitor.
Press <FN> <F4> to toggle between lcd and external monitor to see if it will light an external display.
if that does not work...check your numbers on the bottom against this list. HP knows of flaws on the DV6000X. I loaned a friend a laptop so he could send his in for repair. If the number matches your laptop you are eligible for free repair.
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Screen problem with HP DV 9000
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
Mar 19, 2008 | Computers & Internet
HP Pavilion DV5-1000US Laptop Logo
202 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
