Question about Sharp Actius MM10 Notebook
Sharp Actius MM10 laptop just went dead
Powered up and was opening a file and screen went black and all lights went out
  • suev985 Apr 16, 2009
    laptop has no power; screen is black. I will try your suggestion. Thanx.
  • Sharp Master
  • 32,281 Answers
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 16, 2009
I forgot the password on my sharp actius av18. how do i bypass the password screen and get to the windows screen?
The only way to get that fixed is to call Sharp, and they will assist you in doing a full restore of the computer, what info you had will be lost during this process,
Feb 06, 2013 | Sharp Actius AV18 Notebook
Installing new OS with external drive, it blue screens on startup
hi
please try to reboot the computer with a help of a USB drive .
Apr 24, 2010 | Sharp Actius MM10 Notebook
How to upgrade memory. I need module definition for 1Gig so I can purchase it.
You need a 512MB PC2700 DDR 333MHz SO-DIMM for a laptop (200-pin). The manufacturer I think doesn't specifically support anything over 512MB. But the RAM is standard and I doubt there is any need to buy it directly from Sharp. The laptop only has one upgradable bay so you may not be able to upgrade past 1.25 GB.
One of the memory covers is not removable, if I remember correctly, that is the one under the keyboard. So the one you update is a panel on the bottom.
Mar 11, 2010 | Sharp Actius AL27 Notebook
How i install window in MM10-PC sharp laptop
Installing windows in Personal Computer are needed Bootable at CD/DVD Drive. Your problem is you don't have any CD/DVD Drive.
Use a Portable External CD/DVD Drive.
It's available in the market.
Aug 23, 2009 | Sharp Actius MM10 Notebook
Blue screen REGISTRY_ERROR no CD drive
just go to the cmos!! and the cmos go to the place where you can boot the external or removavol disk!!make sure that ur flash drive is bootable
Jun 30, 2009 | Sharp Actius MM10 Notebook
Ram type for Sharp Actius Pc-RD 10 notebook
My Frenn Don't Bother Yourself, Issues With Your Laptops Doesn't Worth That. Use The Link Below For Your Laptop's Specifications..
http://laptops.alege.net/comments/5893/
You Need To Contact Manufacturer Of The PC To Buy The Parts ..
May 23, 2009 | Sharp Actius RD10 Notebook
Removing files from a dead lap top
If the computer is dead the only way to recover the files would be to remove the hdd & install it as a secondary hdd in another system in order to copy the files. After you are sure all your data is copied you could then either reformatt & keep as a storage drive in other system or remove. You'll need the proper cables as most laptop hdd's just slide into a built in port on the laptop's mb. Hope this helps.
Mar 30, 2009 | Sharp Actius AL27 Notebook
Sharp Actius MC24 PC Notebook overheating and shutting down
If it under warranty I would take it back to them.
If not I would open it up and check for dust build up and make sure the fan is working...
Aug 01, 2008 | Sharp Actius MC24 Notebook
Sharp Actius GP22W - Optical Drive Light on but black screen, seems dead.
hi, first of all remove any disk in the cdrom, as u say the led is on, shut down the system, and check for two things , 1) check the lethium battery, i dont think it should be bad but still, 2) if u are able to locate the RAM, remove it and clean the contacts, place it where it was, if still things dont work, check ur power adapter if the output voltage is same as specified, these are the first aids to ur system, let me know,
Jan 10, 2008 | Sharp Actius GP22W Notebook
Sharp Actius MM10 Notebook Logo
252 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
