Question about Admiral AAV7000A
Washer tub bangs when in spin cycle
I have an Admiral Designer Series top load washer. During the spin cycle the tub bangs so badly that the washer actually moves. The front feet are balanced. What is the problem? I don't have a model number to give you, however a lady asked a question about her machine that sounded exactly like mine and the model # was AAV7000A. Is there a repair guide for parts?
  • dkdzcannon May 03, 2009
    I have the same problem. My washer does this very often and load size doesn't matter and redistributing the load carefully is the only way to get the load finished - it shouldn't be this sensitive. I had a Kenmore for 20 years before getting this admiral and never experienced anything like it. My whole family knows that when you hear the slightest banging, you better get to the machine. My son started a load before he went to work.....when we got home that night the washer was 3 feet away from the wall! This is wrong.
  • 242 Answers
There is not a repair guide , sounds like a spring may have broke or came loose inside on the frame take the front panel off to check for loose parts.
it may just be an off balanced load as well.
Phil
Posted on Apr 15, 2009
  • 234 Answers
Try running a smaller load. Sometimes when you put too big of a load in the washer it will not balance properly.
Sometimes when you have this problem, stop the machine and manually redistribute the clothes so that they look like they are even in the tub and start again.
There are also springs that center the tub in the machine and this could be a problem, but it is not as likely.
There are a lot of distributors of parts online if you need to order parts.
Load banging noise during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 20, 2010 | Frigidaire GLTF2940ES Front Load Washer
During the spin cycle the washer bangs an the inside of it is loose
sounds like ur tub washer on the bottom of the tub is bad its an easy fix but can be difficult to get to
Feb 25, 2010 | Kenmore 23822 Top Load Washer
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Dec 10, 2009 | Admiral AW22 Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Dec 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    Admiral AAV7000A Logo
    532 people viewed this question
    Top Admiral Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
