Question about GE Refrigerators
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
GE Side By Side GSS25WGMCC, 7 years old, up to a week ago had never had ice form on freezer's interior surfaces, had never had to defrost
Excessive mositure forming in freezer, causing ice to form on all interior surfaces of freezer. Compressor is running constantly.
Temperature setting for both frig and freezer set to 5. Have had computer board replaced 3 days ago. Ice still forming on freezer interior surfaces and compressor still running constantly.
I had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Posted on Apr 25, 2009
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Ice melting and frost forming on freezer side, funny sound coming from freezer side. No condensation in back of fridge. Help for a new home owner.
check that your flapper on the ice shut through the freezer door is fully closed,
make sure there is no ice forming around your evaporator fan, thats the fan in the freezer, if that gets glogged with ice and is forced to stop, it could blow your entire machine control......
the frost in the freezer leads me to believe you may have a defrost issue
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
SNOW FORMING IN FREEZER
Could be a number of things. Is the fan running in the freezer section, are the door gaskets sealing completely, even on the bottom of the doors? Could be a defrost issure where the thermotat is allowing it to over heat during defrost and the the cooling cycle starts after defrost and forms the ice an snow from the moisture in the unit.
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer compartment accumulating snowy ice
sounds like an air leak. the ref. is sucking air in and condensing and freezing on that spot. check the gaskets really good.
Jul 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side W/ ice and water dispense
If you have ice forming on the back of the freezer wall it is an indication of a problem with the defrost cycle.Could be defrost timer,hear or termination swith.
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
554 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
