Question about Passport 8500 Radar Detector
Continuous alert I bought an Escort Passport 8500 off ebay in a sealed box and gave it as a gift a month an a half later. When plugged in it is fine on auto for 30 sec or so then starts going off til unpluged. Is there anything I can do? (Unfortunately, I didnt realize that the warranty wouldnt be accepted when purchased from a non authorized seller and the ebay claim period expired so otherwise Im pretty much screwed...)
  • greavous Dec 12, 2007
    almost new x50 and once turned on it will continuously alarm in several different bands. is there a solution other than sending it back or shooting it to death? New from Bestbuy by the way
  • 3 Answers
About the only thing to try with the Escort 8500 and the x50 is to do a full reset. Hold all 3 buttons down while turning the detector on. I believe Escort will still work on it, there will just be a service charge with no warranty.
Posted on Sep 29, 2007
When I accelerate from either a dead stop or if I increase my speed as I'm driving, my lazar alert goes off when there's no threat.
http://tl.acurazine.com/forums/showthread.php?t=629074&highlight=8500
Scroll down a few posts and a guy "blokhead" posts the solution to the "laser" problem. And then another posts some pictures. I only took out the first 3 screws, opened it up, pulled the circuit board out, and then used a tiny screwdriver to seal up the gaps around the metal box around the laser sensors. I also tightened up some of the tabs that hold the box to the board. It definitely had some little gaps that had opened up over time causing RF interference. The guy says if he ever fixes it again he may use some foil tape to completely seal it, I might do the same, but it appears to have fixed the laser issue when you press the gas, and an issue with my keyless remote lock. It would laser everytime I left it on and locked/unlocked the car.
Oct 08, 2009 | Passport 8500 Radar Detector
Dont what to spend extra money if its something simple?
call the factory cause nobody gave me any solutions!!!!
Sep 22, 2009 | Passport 8500 Radar Detector
My passport 8500 stays on Full Alert
First you should try it in another car if possible. It sounds like an electrical problem. You need to rule out if its the car or the radar detector.
Open the end of the power cord it unscrews, check the fuse in it to see if its blown.
Ive also seen the screws loose that hold the circuit board down cause problems. If its out of warranty now, there should be a screw on the bottom usually under a sticker. If you peel that back and remove the screw, and lift the bottom off..Tighten any screw you see holding tbe board down, dont tighten it to hard. Then replace the cover.
Post back after you try some of those, let me know if it still does it.
Mar 18, 2009 | Passport 8500 Radar Detector
Passport 8500 will no longer switch to LOUD mode
Try doing a factory reset as described in the user manual since it is possible that a power fluctuation has somewhat corrupted the internally saved user settings.
Mar 02, 2009 | Passport 8500 Radar Detector
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
Escort 8500 radar detector
Service Required means that your 8500 has repeatedly failed while attempting to calibrate its radar antenna. This can be fixed by Escort for free if your RD still is in warranty. There is a service fee if your RD is out of warranty, but at least Escort will fully test everything in addition to repairing your 8500, and they will upgrade your 8500's firmware to whatever their latest and greatest firmware is which may help to improve sensitivity, reduce false alerts, or to detect newer laser gun models.
Aug 05, 2008 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
353 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
