Question about Cameras
2GB sd card
How do I remove write protect fron card
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position nearest the contacts enables writing, the position furthest from the contacts disables writing, protecting the card. If the switch is already in the enable position, try sliding it fully the other way and then back.
If that doesn't work, then try a different card.
Posted on Jan 24, 2010
  • Donna Gray Jun 11, 2013
    Thanks--that was the solution I needed
SOURCE:
Removing write-protection from SD card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2012 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
How do I unlock a write protected SD removable memory card?
SD memory cards have a tiny slide switch on the edge of the card.
Move the slide switch from write protect (lock) to read/write (unlock).
Jul 11, 2011 | SanDisk 2GB microSD Memory Card
How to remove write protect from my transcend sd 2gb memory card
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 13, 2011 | Nokia 3230
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
My 2GB micro SD card not formatting he say remove your write protect but iam already do this
If it says write-protected, then... there is nothing you can do about it.
It's protected to not be formatted.
Aug 23, 2010 | SanDisk 2GB microSD Memory Card
How to remove write protection from micro sd card
on the adapter that comes with the micro sd card, there is a lock switch on the side of it for write protection. just unlock and youre good to go.
Jul 05, 2010 | Kingston 2GB Secure Digital Memory Card
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
My sd card is showing a writing protection, how can I remove it?
On the side of your SD card there is a sliding button type thing. Try moving it and seeing if this removes your write protection issue.
Oct 31, 2009 | PNY 2GB Secure Digital Memory Card
Cameras Logo
156 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
