Question about Stoves Kitchen Ranges
Cannot open the stove pipe I snapped into a circle
I have a 4 foot piece of round steel stove pipe that I snapped together. How do I unsnap it?
  • htom Apr 18, 2009
    No, I need to open the pipe, not shorten it
Don't unsnap it Cut it to length One way is to use shears Another way is to use abrasive
blade on a grinder I believe you can buy hand shears at Sears they are special snips
that can cut the pipe. You need to use a screw driver to poke a hole in pipe to get started
Posted on Apr 17, 2009
Where do I put oil
Oil is placed where there are two pieces of metal rubbing together.
1. You must look for moving parts while moving the hand wheel. 2. There are some holes on the frame to give you access areas that need to be oiled..
3. The bobbin rides on an indented area called the race. Place one drop at this location frequently.
4. The motion of the needle arm going up and down between two holes needs to be oiled.
5. The pressure foot has a movement of a steel tube (arm) that needs oiled every now and then. The up and down motion of the pressure foot switch has two pieces of steel rubbing together in order to raise and lower the foot. It is important to oil here and on the spring that is inside the tube.
Anyway; make sure you look for steel against steel and oil it.
Jun 28, 2016 | Sewing Machines
Need stove pipe for snow flame corn stove a flexable 90 degree piece coming out from stove and two foot straight piece to go out the exterior wall plus cap piece for outside
You need to communicate with a supplier of this unit to get proper parts and also find out what type/specification of pipe is required in your local area.
Oct 05, 2014 | Dryers
The pole was boxed in 2 pieces which insert together and snaps in place, except i snapped it in backward, now the control end is upside down. how do i unsnap the pieces?
There should be a retainer clip or ball (like a ball bearing) somewhere along the pole that holds them together. Might be hard to locate but should be somewhere within three inches of the end. If you can't find it, go back to the store and look at a new one that is still apart and see what holds them together.
May 09, 2014 | Earthwise Ps40008 8 Inch Corded Pole Saw
Bobins
To "wind" a bobbin you can:
1 - Look in your book
2 - Google : how to thread a bobbin on a kenmore "12 stitch"
3 - Youtube https://www.youtube.com/watch?v=Fe11QQubfqw
4 - Ask a friend
To "make a bobin"
1 - Get some 0.5mm stainless steel
2 - Cut two 19mm circles out of the 0.5mm steel
3 - Drill a 6mm hole in the center of each circle
4 - Solder (silver solder work the best) the 2 circles together with a 6mm round by 9mm tall cylinder in between the two 19mm circular pieces.
Mar 13, 2014 | Husqvarna Viking 1
Poor draft on savannah woodstove
Drolets are a real pain at times. Don't buy their pellet stove. Check your stove pipe to insure its clean and not blocked. This includes spark arrestor. Is you stove cap 2' higher than anything 10' away from pipe? Refer to install manual. If you are not getting an y back draft issues with smoke inside house you may need to add on a section of trip wall pipe at the top.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/william_c9458c4c1f94e482
Feb 27, 2014 | Drolet Savannah 55,000 BTU Wood Stove,...
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
White screen replacing fliex cord need instrutions
As far as I know no one has directions for this.Your on your own.You need to take all the screws out of the phone.The phone basically snaps together.your going to need a security bit type screw driver to take out the screws.Take the phone to a hardware store or sears and check to see what size the screws are.I believe your going to need a number 7 security bit..some times there called a hex key also.You need to take off the back bottom cover.it snaps on.there are 2 screws under the cover.and there are 2 screws on the top of the phone in the back also.you need to unsnap the phone covers apart.Be careful because there is a separate piece that covers the cable and attaches to the phone.The cable runs through that piece.Your going to have to remove the top screen from the casing.No easy way of doing this. just use a skinny screw driver and gently pry it apart till you can pull it apart.You can see where it goes into the casing.After that you may need to take off the silver metal screen over the lcd screen.You can see the cable attaches to the bottom socket on the far left and the other end to the board for the phone.I think there is a piece also covering the cable or bottom part of the lcd screen. that snaps apart but is hard to snap together again.It's round and looks like one piece,but it's actually two pieces.Since both phones are the same,just use one as a guide how it goes back together.I may have skipped a step or two but that's basically how it comes apart and goes back together.Once you take one apart you can see how it's put together and reverse the steps.
May 31, 2009 | Motorola Mobility E815
A key came off the keyboard
Hi eugpol,
Typically, the keys either have a small cross bow type of connection, or they some just snap back on. Look at the back of the key, if it has a round cylinder type configuration, then you can place the key back in it's position and with your fingers, just ad a little pressure until it locks in place.
Now if it has a cross bow configuration, when you look under the key, you'll find two plastic pieces that interlock with each other. What you do is hold the key face up, and sort of tap the sides to get the two plastic pieces to drop. On one of the plastic pieces you'll find two snap in ends. And on the other piece you'll find it's more of a circle that has a snap in bar across the top of the circle. The object here, is to take the one piece that has the two snap in ends and look on the keyboard, you'll find two teany tiny circle holes that those little ends go into. Plug those in first, then on the other side you need to snap the bar end up and back to snap it into place, and your done. It may take a couple of tries, but you'll get it.
Good Luck, and don't forget to leave a rating.
Mark
May 01, 2009 | Computers & Internet
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
Kitchen Ranges Logo
119 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
