Question about Belkin (F5D7230-4) Router (587009)
Can not coneect wireless router to ps3
I have a belkin 125g wireless router and can not connect it to my router . ps3 finds router ok asks for my password which i put in then comes up with an error code.
  • maryhoulden Apr 26, 2009
    ip address frags not support my ps3
  • kmustafa Apr 27, 2009
    have fixed problem was very simple. did not realise my belkin required the ps 3 mac address. it does not tell you anywhere to add that.
Ip address is fragmented when linked to my ps3.
Posted on Apr 26, 2009
    Genius:
  • 1,269 Answers
If you received an error code, that's probably an incorrect wireless password. To verify the wireless password, open the router's admin page using IE and look for wireless security. If you are sure about your password, try to change the wireless channel of your router to channel 11 and power cycle your router by turning it off for 30 seconds then turn it back on.
Posted on Apr 15, 2009
My second notbook is connected but no internet
Call your router's technical engineering support and ask assistance to connect ps3 on their router's wireless connection,., their engineers will update the setting of the router to pair the setting of your ps3,. to connect wirelessly,,.
Jan 02, 2012 | Belkin N600 DB Wireless Dual Band N Router
Where is the wep key located on my virgin router
Connect your desktop computer to your Belkin router, and access the router's built-in web-server software. Then, run the "Wireless Network Setup Wizard", to configure the router's wireless networking capabilities. As part of that process, you will be required to _create_ a "WEP-key" value. Use that value when configuring the wireless capability of your PS3.
Jan 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Software says router working,wireless light not on though,ps3 not able to find acess point when i can for one
The wireless light glows only there is a connectivity between the PS3 and the Router,Kindly follow the steps,
1.try to open 192.168.2.1,in Internet explorer
2.in left hand side below the menu wireless,click on Wifi protected setup,if it asks for password leave it blank and select disable and apply changes
3.Then check in your PS3
You will be able to access the PS/3
Regards,
Ayysam
Dec 08, 2009 | Belkin F5D8236-4 Router
How do i connect ps3 to belkin adsl2 modem with high speed wireless g router ? We have just changed our old belkin (cut out every time the phone rang) for this model and its working 10 times better with...
Network status can be checked in PS3 settings - it says whether the PS3 is connected to the network or not. If you see that it is OK, then you can check the router - it usually lists attached devices, also enable UPnP option if it is not ON yet.
If you have a problem with PS3 in wireless mode - try to connect it to the router with a Ethernet cable (configure PS3 network settings correspondingly) - if it works this way the problem most likely in wifi configuration either on the router or the PS3 side.
I hope this can help
Oct 05, 2009 | Belkin Computers & Internet
I am trying to connect my PS3 to belkin router and there asking WPA2-PSK. Where can i find it?
The security settings for the network should be in the router configuration page. The IP address should be something like 192.168.0.1 or 192.168.0.0. Check belkin's site for the default login to get into the configuration page. Also, post your router's model, then more detailed info can be given.
Oct 03, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless connection
Often the default IP address is 192.168.1.1
If not, the IP address may be printed on the base of the router.
Finally ring up the manufacturer and ask.
Dec 19, 2008 | Belkin (F8T030) (BKNF8T030) Wireless...
Belkin wireless G router not connecting PS3
The PS3 should find the SSID of the network, or you could enter it. And then enter the encryption key, be it WEP or WPA. Everything else should be automatic.
Nov 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin 54g Wireless
please try this
tep 1:
Make sure that your wireless Internet is turned on and working properly.
Step 2:
Turn on the Playstation 3 game console.
Step 3:
Access the "Network Settings" screen under the "Settings" screen in the main menu.
Step 4:
Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
Step 5:
Select "easy" on the new screen that pops up asking what type of installation you want to use.
Step 6:
Select "wireless" when it asks you what type of Internet connection you have.
Step 7:
Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
Step 8:
Select your home Internet when the screen pops up displaying the available Internet options.
Step 9:
Save your settings on the next screen.
Step 10:
Test the connection to make sure that it works properly.
Make sure your wireless Internet connection is at full strength.
Hope it helps!
Nov 05, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
220 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
