What model Lucent router is it? If it's an older one (DSLPipe, for example) it won't be able to handle the PPTP connections due to a hardware issue. If that's the case, the best solution would be to request that your ISP (if they supplied it) disable NAT on that router and assign you a block of public IP addresses. That way the router will just directly pass on the traffic to your IP address and VPN would work just fine.
Regarding a phone number, Lucent was merged with Alcatel in April of 2006, so you may need to contact them. Their contact numbers can be found here:
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
I have a netgear RP614 my nat is to strict to connect to some friends in online games.How do I open...
(More)
I have a netgear RP614 my nat is to strict to connect to some friends in online games.How do I open this on this model
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the...
(More)
DL 524 signal intermittent! The wireless connection drops when more than 1 user is trying to use the internet at the same time. It also drops when I get an incoming message on my blackberry.
we have lost connection from our lap top and the wireless light on the router is out. i hope you can...
(More)
we have lost connection from our lap top and the wireless light on the router is out. i hope you can help. many thanks
