Question about Frigidaire Affinity ATF7000ES Front Load Washer
Clothes soaking wet after cycle completed
When the load of laundry has finished washing, the clothes still have soapy residue and are wet, wet, wet. I tried switching from one setting to another (from normal to permanent press) and still the wash cycle is not complete.
  • Anonymous Jan 26, 2009
    I have the same problem as you. In fact I have been really 'itchy' recently and it only just dawned on me that this is probably the reason.
  • Anonymous Feb 15, 2009
    My machine is not spinning either. How can my husband fix this?
    Thank you.
  • 7 Answers
Sounds like it's likely a clog in your drain line. I'd start by checking that. Your best bet is to take off the back panel, unclamp the line (it's grey) and checking it with a wire hanger. If that doesn't work, do the same thing to the line that connects to the exterior drain line.
If both those are clear, the next thing it could be is the actual pump--and, possibly, specifically the motor for the pump. I'd check the pump line and assembly first, using the information found here: http://www.fixya.com/support/t289401-error_code_20. I had the same problem as you shortly before I started getting the error code 20, and you'll see how I (and others) solved it. I recommend trying the shortcut Keith_Mann offers and if the white basket has not gotten forced into the central pump chamber as it did with mine.
If there is no clog in the pump or drain line, the problem is likely the actual motor of the pump. I'd recommend troubleshooting it by leaving the back panel off, then taking a towel you've thoroughly wetted down and placing it in the drum and setting your machine to spin. Make sure the washing machine is still turned around so you can see the back assembly. Crouch down and watch to see/hear if the pump motor is activating. If not, you'll have to call a repairman to have it replaced.
Good luck. Hope you can fix it yourself!
Posted on Apr 03, 2009
  • 725 Answers
Looks like you washer is not spinning your clothes out and maybe not agitate them either. Start your machine normaly on heavy load, watch it and check if it fill and moves back then drains and goes into a spin.. if water is still in the machine then you may have something stuck in the drain. If it fulls and drains then you may have a motor or control problem. If its still under warranty you will need to call authorized repair service or authorized frigidaire service. if not under warranty and you want to repair it yourself let us know and we can help.
Posted on Sep 15, 2007
Sludge On white clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
How do you clean **** buildup in a top load washer?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
9.2 Soiling
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
9.5 Black Marks on Clothes
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
9.6 Grey Marks on Clothes
this is a problem it is recommended that the machine be periodically filled with hot water, plus
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
We have a WFL 2090 UC Bosch Axxis Front end load washer. When we use the Power Wash option, the clothes are soaking wet when the cycle is completed. Are we supposed to use the Power Temp or Power Boost...
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
Jun 28, 2009 | Bosch Axxis WFL2090UC
The word "suds"
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
Dec 27, 2008 | Maytag MAH8700A Front Load Washer
Shuts off in middle of cycle
I am having the same problem w/ our brand new front loader washer, it pauses constantly, and even when I can get the load to finish, I have to drain and spin atleast 3 x before I can even attempt to put in dryer, at this point it is taking me hours to do one load of laundry!!
Ugh-- Service man is coming tomorrow, so I will share what I learn...
Apr 19, 2008 | GE WBVH6240F Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Washing Machines Logo
246 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
