Question about HP Photosmart 2610 All-In-One InkJet Printer
New black print cartridge not working
After two years of the 2610 printer running flawlessly,the printer now prints with very light black print on the paper. I have tried two brand new cartridges with no success. Is there some thing I need to clean to get this thing working right again? Has anyone experienced this problem?
  • Kudell Jun 15, 2008
    I have exactly the same problem, as I have moved from Uk to Australia. I was told by Hp support I needed to take out an extended warranty for them to help!!
    If you have a solution please let me know.
    Thanks
I only use refill HP inks. When the cartridge prints gray instead of sharp black it means the ink well is clogged. Yes, that can happen on a new cartridge. Sometimes it happens when they put too much ink in the cartridge, or even heat can make it not work. Also streaking black lines is the problem of the ink not coming out properly. Easiest thing to do is go to a refill station like Cartridge World and have them test it or clean it out. You can also make sure the printer, not the cartridge is clean. Ink builds up an pools. Get some Q-Tips and clean up all that spilled ink. Sometimes in the software it says you can clean the print head, do that too.
Posted on Jun 17, 2008
  • 54 Answers
In printers there are types of mode in printing these are draft, normal, best, and sometimes theres also an enhance mode. check your printer properties before you start another print, check whether it is set to the said mode. i suggest that you set it in normal mode. this is the usual mode used in printing. then lets see.
Posted on Sep 21, 2007
SOURCE:
MY HP 2610 ONLY PRINTS THE TOP HALF OF THE WORDS ON EVERY SECOND OR THIRD LINE OF BLACK PRINTING
You need to clean the nozzles of the ink cartridge by dabbing on a wet paper towel folded many times, after the water you dab on a dry area to see if there's a solid black line. If it's a refilled cartridge it could be just worn out, they're only good for about 2 refills.
Jan 18, 2010 | HP Photosmart 2610 All-In-One InkJet...
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
I cannot get my new black print cartridge to align properly. I am using the HP Photosmart 2610 all-in-one device.
I bought a new ink cartridge which will print well. But the alignment still does not work for some reason. The printer screen says to "check the device instructions" whatever that means. i am willing to continue to use the printer as is unless you have a simple solution. Thanks Gerald Lord
Jul 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Remove and check color cartridge
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-in-One Printer scanner
HP forces you to have the color cartridge INTACT to DO ANYTIHNG. TIHS IS A POS AND AGAINST FEDERAL LAW.
Jan 13, 2008 | HP Photosmart 2610 All-In-One InkJet...
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
HP PSC 1350v Check Print Cartridge Light
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge (office depot) I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
1,203 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
