Photoconductive drum is coated with toner on sharp sf-2214 copier.
Need to have the drum cleaning blade replaced, and likely the drum to.
Posted on Apr 16, 2009
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
I have a sharp sf2116 copier. when copying i am getting half of the page printed properly but the other half is feint. i have renewed the toner.
problem is not the toner , could be the developer unit stopping at that point when it becomes feint and then no new toner gets to the drum,
OR
it could be the transfer section
Aug 06, 2013 | Sharp SF 2020 Copier
How to empty toner box
open front cover remove toner cartridge release copier open drum unit ,pull out you can see waste toner box
May 09, 2010 | Sharp SF 2020 Copier
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
Our nonprofit got a sharp sf-2040 donated. It prints a too light of a copy. I tried to replace toner it was full. No keys or directions light up - does it need a new drum or something.....??
There are several solutions to this problem:
1. Adjust the exposure
2. The drum may be out.
3. The developer may be out.
4. Finally, You may need a PM for the copier. (replace the drum, developer, drum blade)
Jun 11, 2009 | Sharp SF 2040 Copier
How do I reset the drum and PM counters on a Sharp SF-2214? The red drum and technician lights are on on the control panel, even though the drum has recently been replaced.
To get into service mode press the following keys one after the other "clear" "interupt" "0" "interupt"
To clear the drum counter : enter "24" then "start key" "7" then "start" key.
To clear maintenance counter : enter " "20" then "start" key then "1" then start" key.
restart copier and the flashy thing should be history.
Mar 20, 2009 | Office Equipment & Supplies
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Sharp sf 2114 too much toner on copies
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Nov 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
307 people viewed this question
jasbo
jasbo
