Question about Freezers
Top of freezer is warm and bottom is forming ice. What do I replace?
I have a maytag MQU1554AEW upright manual freezer. The top won't get cold and the bottom is forming ice. What is causing this?
  • 242 Answers
The cause if no defrost cycle , remove the panel where the ice is and derost with unit unplugged , use a hairdryer or similar to defrost ice , make sure its all defrosted , check the heater under that coil to make sure its still intact.
Also check the defrost timer , there may be a wiring diagram on the back showing where this is located.
Phil
Posted on Apr 15, 2009
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice forms at the bottom very solidly Model: Maytag MQU1656BEW 15.7 cu. ft. Upright Freezer with auto defrust
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Jul 20, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
Sep 19, 2010 | Maytag Freezer MQU2057
Upright freezer problem
Hi, I don't know if it were I that helped with you're solution or someone else as we have many, many, techs. Please let me know by my user name.
Shastalaker7
Thank You
Mar 21, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Ice in bottom of upright freezer -- problem with tube position?
Hello, get a short piece of electrical wire and strip the insulation off. put a bend in one end and then hang it over the heater directly above the drain making sure the wire runs into the drain about an inch. the heat from the heater will make sure the drain stays clear. Hope this helps. Mike
Nov 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezers Logo
237 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
